Dimensions needed: Missing Links w/YJ'
  • 1207 Views
Offline zuki1018
  • 397
« on: May 03, 2012, 09:33:02 AM »
Hey folks.  Working on the installing the YJ's on the back corners of my Sami.  Wondering if anyone can offer up the hole-to-hole measurements on both shackles from a manuf. kit so I can build them.
On a side note, I noticed of the 4 "YJ" springs I bought from a member here, 2 of them are 4-pack leafs and the other 2 are 5-pack with the bottom-most cut in half... or 4.5 pack.  I am not sure which direction to mount these 4.5" odd ball leafs... or if they should be on the front or rear.
My goal here is as soft of a ride as possible.  I removed the 3" Calmini lift leafs... horribly stiff ride.
TIA
« Last Edit: May 03, 2012, 09:36:04 AM by zuki1018 »
Re: Dimensions needed: Missing Links w/YJ'
« Reply #1 on: May 04, 2012, 08:36:47 AM »
The half-pack is for the rear and supposed to be mounted with the longer part facing towards the back.  This is to help deal with axle wrap without effecting the ride.  I have seen with muscle car spring packs they have a similar setup but on the top going forward for the same action.   I would scrap it and go with a real traction bar instead but it's better then nothing.
Offline SIDEKICK65
  • 176
« Reply #2 on: May 19, 2012, 04:18:52 PM »
So i have the same spring's that i'm gonna use under my sidekick.so if i read it right i'm going to put the 4 leaf's in the rear and the 5 leaf's in the front??
Offline zuki1018
  • 397
« Reply #3 on: May 21, 2012, 07:14:32 AM »
visa-versa
