how to installed a powersteering on a samurai 1.3
  • 3462 Views
Offline jtigki
  • 43
« on: March 28, 2011, 08:20:15 PM »
I bought the kit for my 1.3 samurai only problem I have id that the pump is to close to the steering box? any suggestion.
  • 6602
  • 69
Re: how to installed a powersteering on a samurai 1.3
« Reply #1 on: March 29, 2011, 08:21:00 AM »
Who's kit did you buy?
Offline jtigki
  • 43
« Reply #2 on: March 29, 2011, 12:28:12 PM »
roadless gear kit
  • 6602
  • 69
« Reply #3 on: March 29, 2011, 01:20:14 PM »
The pump will be close to the box but should not touch it. This design is very common and standard.. Assuming your vehicle is stock and the kit was manuf to spec and you have interference issues, it could be because you've got a broken motor mount or something like that.
Have you tried to install it yet?
On this photo from our Reynold's engine article you can pretty much see how tight it does get in there. The kit shown is a Calmini kit but most of the Sidekick to Samurai p/s kits are very similar.
http://www.zukiworld.com/month_060101/feature_reynolds_01.htm
Hope that helps, -Eric
Offline jtigki
  • 43
« Reply #4 on: March 29, 2011, 02:57:23 PM »
yes but im waiting for the joint eliminator to come
Offline jtigki
  • 43
« Reply #5 on: March 30, 2011, 06:21:44 PM »
Tks guys for all your help! I found the problem the engine was leaning on the driver side about an in. now its striat fit real good now!
