98 Kick Sport - Spark plug issue
  • 11 Replies
  • 3233 Views
Offline Dennis .89-
  • 54
  • I Owe I Owe, So Off To Work I Go!!
« on: August 10, 2011, 09:08:39 AM »
so i have gone though 4 spark plugs in past year and i don't even get over 5,000km on the engine.
and lately i have studering issues with my zuki too. anyone have a problem like this before?
.Dml-
oh and also forgot to mention its all white on the spark plug and thats from to much heat i believe.
« Last Edit: August 10, 2011, 09:34:41 AM by Dennis .89- »
Offline mrfuelish
  • 2862
Re: 98 Kick Sport - Spark plug issue
« Reply #1 on: August 10, 2011, 09:31:07 AM »
yep, changing plugs today on one, will try to let you know how it went, codes said it was missing on one and two so will swap coil packs to three and four and see how that goes.
Offline Dennis .89-
  • 54
« Reply #2 on: August 10, 2011, 09:54:41 AM »
i think i might have found my problem, the store gave me +6 heat range bosch plugs and the kick needs +7
at least that's what the bosch site says.
Offline Jluck
  • 1389
  • 40
« Reply #3 on: August 10, 2011, 06:22:24 PM »
Timing or fuel quality maybe?
Offline mrfuelish
  • 2862
« Reply #4 on: August 10, 2011, 06:26:19 PM »
Well i put the plugs in and it helped a little bit but number four is dead now so I made a phone call and was told that the coils get corroded on the inside and that they come apart and you can clean them so I will try that in the next couple of days and see how that goes, I'm going to order a couple of used ones just in case I take a hammer to them if they give me any problem at all Lol.
Offline mrfuelish
  • 2862
« Reply #5 on: August 10, 2011, 06:28:23 PM »
What kind of plug did you buy? I hope it was not a +2 or a +4.
Offline Dennis .89-
  • 54
« Reply #6 on: August 13, 2011, 05:55:26 PM »
i just bought the Bosch Plat Plus with +7
and there working which ones do you think i should try?
Offline mrfuelish
  • 2862
« Reply #7 on: August 13, 2011, 09:38:50 PM »
I just don't like plugs that have more than one ground to go to, it just confuses the electricity at high rpm's, you can cut them back (all but one on each) and make a good plug out of them and even index them if you want to while your doing it (I know I'm showing my age) it all depends on how hard you drive your rig.
Offline jeff1997
  • 1228
  • 27
« Reply #8 on: August 14, 2011, 06:53:33 AM »
I had the same problems on my 97 1.8L. It is the coil packs. They start to go bad and arc through the rubber onto the surrounding metal. I used cheap NGK plugs all the time and they worked great. Get the coil packs off ebay but watch which ones you get, the model year is critical. They make several ones that only fit certain years.
3" Masterkit1 body lift
Custom strut spacers
« Reply #9 on: August 14, 2011, 07:50:34 AM »
The 96 & 97 use a different coil pack to the 98 - on those years the ignitor is a separate module, on the 98 the ignitor is built in to the coil pack.
Offline talonxracer
  • 1284
« Reply #10 on: August 14, 2011, 08:16:38 AM »
There is absolutely no confusion occuring at high rpm's, what you get is dillution, with more than one ground strap the electrical charge can use multiple straps at the same time reducing the current seen at each ground strap, and with a reduced electrical charge at each ground strap you get misfires.
Offline Dennis .89-
  • 54
« Reply #11 on: August 18, 2011, 08:52:00 PM »
ok that will be my next upgrade thanks for the info guys
