snorkel for 2000 tracker
  • 3192 Views
Offline bigmark8
  • 8
« on: August 10, 2017, 07:38:07 AM »
does anyone know of a snorkel kit for my 2000 tracker.
Re: snorkel for 2000 tracker
« Reply #1 on: August 12, 2017, 09:30:27 AM »
There are a couple of suppliers - OGZ in Brazil and FTS out of Taiwan.
Be warned - an ebay search may pull up several listings for snorkels advertised as fitting - ask to see the template before purchase - if it's a rectangular template with a rectangular hole for a turn signal - then it does not fit the vehicle you have without modification.
Offline bigmark8
  • 8
« Reply #2 on: August 18, 2017, 07:24:52 AM »
thank you
Offline Lena01
« Reply #3 on: October 14, 2017, 03:09:11 AM »
hi all, my name is Lena)) I am a new member here )) thanks for your post , nice to meet you all here, in this web site
« Reply #4 on: October 28, 2017, 04:30:54 PM »
My snorkel came out of Singapore and it had the European / Asian template. I had to do a lot of measuring to make sure that I drilled the hole in the right place.  It was still off by about 1/8" (3mm), but I was able to adjust the hole. It was all covered by the snorkel.
The biggest issue is making sure you pick the right engine style.  The Asian models had a V6 when they were not available here. The other issue is if it is a J series or G series engine. The intakes are on opposite sides.
« Reply #5 on: October 28, 2017, 05:10:14 PM »
Ridjobradi - what vehicle are you referring to?
The original poster is asking about a 2000 Tracker, which is going to be an SQ series vehicle, SQ series vehicles were available in the US market with the G16 & J20 four cylinder engines or the H25 V6, non-US markets had the same three gasoline engines along with two different diesels, depending on the year of manufacture - the intake is on the right side of the vehicle, regardless of which engine is fitted.
« Reply #6 on: October 31, 2017, 07:05:34 AM »
It was meant as a general statement when looking for snorkels from other markets.  I also didn't know that they moved the air box to the right side for the G16.
