suzuki sidekick "undertaker"
  • 11 Replies
  • 3942 Views
Offline Dennis .89-
  • 54
  • I Owe I Owe, So Off To Work I Go!!
« on: November 02, 2011, 06:19:30 PM »
i was looking into getting the undertaker so i can drive on highway at lower rpm
how hard is it to install any one have any idea?
is it a 1-4day type thing? because its a DD for the moment and have no spare car.
thanks, Dennis
Re: suzuki sidekick "undertaker"
« Reply #1 on: November 03, 2011, 04:44:08 AM »
That depends on your working setup, tool selection and skill level. Try giving Brent at Trail Tough a call since he developed and sells them.
Offline talonxracer
  • 1284
« Reply #2 on: November 03, 2011, 05:33:43 AM »
The undertaker is not an overdrive, but an underdrive, ie a reduction box that INCREASES your RPM's if the R&P's are left the same as you currently have installed.
The main useage is when this reduction drive is installed along with lower diff gears(4.6) to gear for 33"+ tires.
You will need custom driveshafts front and rear as well, and I would seriously consider slipjoint eliminator output shafts.
On a 2dr it will really shorten the rear driveshaft, the best application is with the longer 4dr sidekicks
« Last Edit: November 03, 2011, 05:35:23 AM by talonxracer »
« Reply #3 on: November 03, 2011, 05:51:36 AM »
If it were me, I'd say around two days - but - to do that I would need to get the modified driveshafts before I started, and to be honest, I would not attempt it without a spare car available.
About the only work I'll do on my car without a spare available is an oil & filter change - if I tackled something like installing an undertaker that would pretty much guarantee that I'd have a problem for example one of the bolts holding the crossmember in place would shear or strip - nothing that I can't fix - but there will be something that would necessitate a parts run.
Offline talonxracer
  • 1284
« Reply #4 on: November 03, 2011, 06:20:59 AM »
Mr Murphy will always arrange a visit at the most inopportune time.....
Offline FireCkrEd
  • 246
    • My Church-San Pedro Revival Fellowship
« Reply #5 on: November 03, 2011, 06:12:29 PM »
   Brent hasn't had good luck with the undertaker, tolerances  in the case caused all kinds of problems with it like vibration and noise. He had to find a machine shop that would do a better job of it. I had the chance to take a look at one in Petroworks shop and from what I saw I would not buy one. There are no locating pins in the case the bearing were too small and the bearing were not pressed into the case so if a bearing went bad it would spin in the case and ruin the case. Call Petroworks and discuss it with them. Gary is a HONEST guy and the guys in the store are great too. Iv'e never had a problem with them trying to see me something that would not work or something I didn't need.
          Ed
93 4dr Kick, stock, + 95 4dr W/TTough kit, Toy axles, 4.24 xfercase gears, 5.71 gears, Ramsey 9500 winch, twin stick xfercase, 33" BFG's
97, 4dr with a 2" lift (needs an engine re-build)
Spirit Filled Christian
Offline Dennis .89-
  • 54
« Reply #6 on: November 03, 2011, 07:20:42 PM »
if its an under drive how come they say it'll let you dive on highway with bigger tires?
ohhh okay sorry i completely read it wrong... i though it was backwards.
to much work lately i guess can't think straight.
« Last Edit: November 03, 2011, 07:48:06 PM by Dennis .89- »
« Reply #7 on: November 04, 2011, 05:00:09 PM »
Well I for one wish someone would make an OVERDRIVE for the 3 speed autos.
« Reply #8 on: November 05, 2011, 05:53:39 PM »
They do.  It's called a "4 speed auto". :P
« Reply #9 on: November 06, 2011, 05:35:49 AM »
Yes, but not a bolt in  ;D All them wires and computers, I'm getting a headache thinking about the swap ! I guess I'll just stick to the right lane at 65.
« Reply #10 on: November 06, 2011, 05:43:00 AM »
Unless you do the volvo 4 speed.  Which in not computer controlled.
« Reply #11 on: November 08, 2011, 03:30:24 AM »
Yeah, I've looked into that as well, but you need to get all kinds of stuff, shifter, tail section, torque converter, etc, etc. I'm getting lazy in my old age and just want to bolt it in.  ::)
