largest tire size with calmini 3" suspension lift
  • 8 Replies
  • 2581 Views
Offline manning
  • 24
« on: July 24, 2010, 02:40:25 PM »
as the title says whats the biggest(or optimal) tire size to not rub at full lock and flex with just a 3" calmini suspension lift(no BL) on a track or kick???
and does anyone know what the ground clearance would be with that setup???
TIA for your replys
Bryan
Re: largest tire size with calmini 3" suspension lift
« Reply #1 on: July 24, 2010, 03:30:45 PM »
31" will fit, clearance, about 10" at the diff bottom
Offline manning
  • 24
« Reply #2 on: July 24, 2010, 03:54:47 PM »
 8)thanks for the quick reply
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #3 on: July 24, 2010, 04:11:37 PM »
Skinny 32's like a 7.50-16 or a 235/85R16 but if you are willing to cut and hammer then ........
Don't forget that different rims will have an impact due to width and backspacing/offset.
Offline camokick93
  • 47
  • SUPPORT OUR TROOPS
« Reply #4 on: August 02, 2010, 03:34:53 PM »
Hi,any larger than 30in it will rub unless you trim fenders,here's mine with 30in tires,no body lift,no trim,with a tweeked Calmini 3in lift witch gives me 4 inches of lift.
93 4door sidekick,5spd,3in calmini,ome frt coils with 2in spacers,calmini winch bumper,8500 superwinch,calmini front skid,custom rock slidders,custom belly pan,frt ome shocks with upper mount flip,4.24 t-case gears,truck painted camo,hence my user name.I have rear ARB,calmini header exh. combo to be installed soon.FOUR DOORS KICKASS
Offline camokick93
  • 47
« Reply #5 on: August 02, 2010, 03:38:47 PM »
Here are clearance measurements diffs and at rock sliders.
« Reply #6 on: August 03, 2010, 04:39:14 AM »
A great way to get better fender clearence is doing the Hagen widening at both front and rear when putting in a new lift. It moves both front and rear wheels back to the center of the wheel well giving you more room for bigger tires. I'm running 32x11.50 with no fender trimming, and just a bit o rub at full stuff on the right rear fender inner lip. A little work with the channel locks took care of that.
Offline ecoast
  • 509
  • 8
    • East Coast Canvas
« Reply #7 on: August 03, 2010, 12:39:20 PM »
... I'm running 32x11.50 with no fender trimming, and just a bit o rub at full stuff on the right rear fender inner lip. A little work with the channel locks took care of that.
w/o bumps stops these will jam in wheel well at full compression...preventing motion.
right, Mike?
« Reply #8 on: August 03, 2010, 03:05:44 PM »
OH Yeah! Don't forget the bumpstops! And a 32 or 33 10.50 would be better!
