Calmini EDSE Kit
  • 63 Replies
  • 29559 Views
Re: Calmini EDSE Kit
« Reply #60 on: March 27, 2016, 01:03:52 AM »
Yuri
Will you explain the suspension geometry improvements that were gained by building a link that is even longer than Calmini's 2nd generation longer link.
Do you mind explaining how you went about fabricating the longer link.
Did you modify the Calmini link?
I like the Orange color.
Curious what the story is behind all the vehicles being the same color.
Online RJkick
  • 634
« Reply #61 on: April 12, 2016, 02:14:46 PM »
I tested the flipped shock and unfortunately I blew out the driver's side shock.
The rear shocks of a '95 Ford Aerostar seem to work best so far
Most likely am going to grind the middle of the upper arm gusset to see if I can get rid of the issue
More to follow
Online RJkick
  • 634
« Reply #62 on: February 23, 2020, 10:05:44 PM »
Anyone with updates on the Kit
Mine is working really well with the exception of the shocks
Still trying to find a long lasting "desert running" shock
Online RJkick
  • 634
« Reply #63 on: March 04, 2020, 12:04:48 PM »
Trying ProComp 9000
