CALMINI reverse shackles
  • 28 Replies
  • 8917 Views
Offline unbridled
  • 33
Re: CALMINI reverse shackles
« Reply #15 on: June 01, 2010, 10:21:49 PM »
Cool, thanks for the heads up!  How's the ride and flex?    I might steal your idea and just go with one a hair longer.  Gotta get some new rubber on the Sammi first.
  • 6589
« Reply #16 on: June 02, 2010, 11:13:04 AM »
Offline woof359
  • 111
« Reply #17 on: June 02, 2010, 05:14:13 PM »
i went with Monroe matic 31000 on the back, took it for a ride, all for shocks work great.
CHUCK AND MICHELLE
Offline woof359
  • 111
« Reply #18 on: June 02, 2010, 05:20:05 PM »
dam, wish I wood have found that earlier, it wood have saved me  a trip, but many thanks any way (-:
CHUCK AND MICHELLE
Offline unbridled
  • 33
« Reply #19 on: June 02, 2010, 05:22:33 PM »
Good to know.  Thanks for letting me steal your hard work...
Yeah, I should have searched but this thread was calling to me.
Offline woof359
  • 111
« Reply #20 on: June 02, 2010, 08:13:37 PM »
the ride is a bit more stiff, not much but you do notice some diff, no worse than a jeep with a lift kit, i kinda like it (-:
CHUCK AND MICHELLE
Offline cmatt1605
  • 51
« Reply #21 on: June 08, 2010, 06:29:36 PM »
2 things.
1- i love the way your sami turned out. it looks awsome!
2- this is the same lift kit i wanna get and was wondering what size tires u are running and what size rim?
« Reply #22 on: June 12, 2010, 08:47:45 AM »
Is this lift enough to clear the front axle for a 1.6L 8v swap? Just scored a engine for $400 and now ready for a swap.
  • 6589
« Reply #23 on: June 14, 2010, 07:21:22 AM »
If you leave the bumpstops at factory heigth (which I recommend) You need to use the 1.3 oil pan and modify the pickup tube to work... Then your dandy... If you use the included bumpstop extensions, you do not need to modify your 1.6 oil pan and it'll fit nicely.
Offline woof359
  • 111
« Reply #24 on: June 20, 2010, 02:30:13 PM »
Ok, had the chance to go mudding the other day, been raining here for 2 weeks (-:
after installing the Calmini reverse shackles ans installing new shocks it rides great, easy to install and I can add springs later if I wanna use bigger tires than I have now,  15 by 8 CJ7 rims with 235X29X15 tires
note to self, when tires stick out further than flares make sure you have doors ................(-:
CHUCK AND MICHELLE
Offline cmatt1605
  • 51
« Reply #25 on: June 20, 2010, 05:50:18 PM »
nice to hear it handles great! but 235x29x15? that seams kinda smaller than what you have. you mean 235x75x15???
Offline woof359
  • 111
« Reply #26 on: June 25, 2010, 01:48:50 PM »
235 75 15, , , ONCE AGAIN I NEED TO PROOF READ POST. THANKS , NOW IF I CAN JUST GET THE BETTER HALF TO GO FOR A MUD RUN...............................
CHUCK AND MICHELLE
Offline cmatt1605
  • 51
« Reply #27 on: June 25, 2010, 02:07:30 PM »
ahh good luck, i have tried that on several occasions. no luck so far haha
Offline woof359
  • 111
« Reply #28 on: July 17, 2010, 02:03:42 PM »
WERE SUPPOSE TO GET A HELL OF A STORM TONIGHT, iM HOPING TO GET HER OUT IN THE MUDD ONCE (-: 8)
CHUCK AND MICHELLE
