cams for 2.0
  • 2537 Views
Offline philc72
  • 65
cams for 2.0
« on: January 03, 2010, 05:53:11 AM »
sorry bout all the ?'s are there cams for the 2.0 available I cant find any.
Offline cj
  • 1276
  • I drive a really big ATV
Re: cams for 2.0
« Reply #1 on: January 03, 2010, 01:02:59 PM »
Not really. Ask around on the Aerio or SX4 forums as I think someone was looking at them, maybe Road Race Motorsports? I did find one place in Europe but you needed to sell a kidney for them.
You could always get these as he still has them http://www.trademe.co.nz/Browse/Listing.aspx?id=261970541
You could also try contacting superfly on the TeamSwift forum as he does cam work.
Offline dustybadlands
  • 169
    • dustybadlands treeslammer
Re: cams for 2.0
« Reply #2 on: February 07, 2010, 06:36:04 PM »
How could we find out if there is a difference between the cam shaft of a 127 HP Tracker, and the 145 HP Aerio?
"If nuthin' changes, nuthin changes. Do what ya  always did, get what ya  always got !"
Re: cams for 2.0
« Reply #3 on: February 08, 2010, 09:36:47 AM »
You could compare the part numbers - or - you could compare the cams themselves.
There are two different cams listed for the Aerio (based on the MY) - 12711-62G00 (intake) and 12721-62G00 (exhaust) - for the second set, change the last five characters to 62G01 - this of course does not tell you what the differences are, but only that there is a difference.
The Vitara which I believe uses the same cams as the Tracker uses the first set of numbers above (the 62G00 ones.
Maybe comparing the cams themselves would be the better way to go - for a quick & dirty check grab a caliper and measure the height of a lobe, if they are the same then the cam is probably the same - note this would not be definitive as you are only looking at lift and completely ignoring the actual timings & duration.
Re: cams for 2.0
« Reply #4 on: February 08, 2010, 09:10:47 PM »
Keep in mind it's not all about HP, you need torque to move a load, and
if you have a heavier vehicle, (Tracker vs Aerio) you might not like the
end result
Bobthebiker
Re: cams for 2.0
« Reply #5 on: February 08, 2010, 09:30:07 PM »
end result
This is extremely true.  diesels are excellent examples of this truth.  low rpm torque is great for many things, except top speed really.
  • 169
Re: cams for 2.0
« Reply #6 on: February 09, 2010, 07:54:41 AM »
Well, looks like I'll get to see for myself. The GF's Tracker is getting the Aerio engine with Tracker aspiration. As soon as I plug up the leaky tranny. ;)
