2" coil and strut spacers with gv springs
  • 1832 Views
Offline jas3924
« on: December 05, 2010, 06:48:30 PM »
i just got a 96 Suzuki sidekick a couple months ago and was wanting to put a 2" coil and strut spacer lift on it but found out that i can use grand Vitara springs to get extra lift. I was wondering if i combined the two if i would have to change anything other than the shocks to make this work, or would i run into other problems
Offline mike5721947
  • 545
Re: 2" coil and strut spacers with gv springs
« Reply #1 on: December 06, 2010, 06:24:20 AM »
front gv coils on a 2dr softtop give 2-3" lift rears give 1" so rear needs some more lift to make it all work right. i have gv coils in my 90, works pretty good, needs the spacer in the rear to level it out but it clears 31's
31" kumhos 3inchs of lift.
Offline mike5721947
  • 545
« Reply #2 on: December 06, 2010, 12:12:45 PM »
DON'T use both gv coils AND spacers up front. the gv coils almost max out the stock cv's unless you are willing to drop the diff and modify more of the suspension leave it at just coils or spacers up front
Offline jas3924
« Reply #3 on: December 06, 2010, 12:33:14 PM »
thanks, i think ill go with the gv springs and use a spacer to level out the rear
« Reply #4 on: December 06, 2010, 02:47:02 PM »
That is what I run on my 96 Tracker.  1" spacer in the rear, 1" coil spacer and GV springs up front.  It does run a bit stiff, but softer then when I ran the spacers up front with stock springs.  Just don't expect to keep your stock rigs ride quality.
« Last Edit: December 06, 2010, 04:51:17 PM by Drone637 »
Offline jeff1997
  • 1228
  • 27
« Reply #5 on: December 06, 2010, 03:16:01 PM »
I can supply the coil spacers in whatever size you need.  8)
3" Masterkit1 body lift
Custom strut spacers
