Battery Box
  • 1723 Views
Offline RJkick
  • 634
Battery Box
« on: April 26, 2019, 01:17:23 PM »
Anyone build or buy a battery box?  I have a 92 4dr with the EDSE kit so water comes up through the strut tower and my battery gets corroded.  I thought maybe a battery box to keep it dry
Re: Battery Box
« Reply #1 on: April 26, 2019, 01:33:53 PM »
What sort of battery do you have?  Automotive batteries generally do not "corrode" because they get wet, so I want to think what you're looking at is more likely to be a defective battery.
Offline RJkick
  • 634
Re: Battery Box
« Reply #2 on: May 02, 2019, 02:11:50 PM »
That may very well be - I took a look and it was 7 years old - I was shocked and then replaced it and added the brass connections so I should be good to go
thanks
