fitting 32's
  • 1334 Views
Offline airmanwilliams
  • 913
fitting 32's
« on: June 21, 2011, 07:33:21 AM »
will adding 2" shackles to my 3" deaver spring under clear 32's? anyone have this setup or try it once?
1993 4door Suzuki Sidekick JX
Re: fitting 32's
« Reply #1 on: June 21, 2011, 10:40:10 AM »
It will be close, but with some heavy fender trimming/hammering they should fit.  Depending on your backspacing they will rub on the back of the fender well.
Offline tuxblacray
  • 20
    • Tuxblacray Photos
Re: fitting 32's
« Reply #2 on: June 21, 2011, 02:51:47 PM »
Are the shackles 4" hole to hole and provide 2" lift? If so I think the will fit with some trimming to the bottom corner of the fender. What tires are you reunning now? How much clearance do you have between the tires outer tread and the bottom rear fender when you are turning?
