302 v8 swap in '96 tracker
  • 7 Replies
  • 4428 Views
« on: September 20, 2012, 11:11:10 AM »
I have recently been interested in acquiring a 302 motor in running conditions for under a hundred bucks. At the same time, I have been researching this topic throughout the web on how this swap can be done. My tracker is currently 2wd with a t-case, no front axle. Is it possible to swap the 302 with the c4 tranny and keep the stock tracker rear end? the motor is stock. I will eventually switch over to an 8.8 rear and dana 30 in the front but just out of curiosity, can this be done? Any other little hints or tips will be greatly appreciated
Re: 302 v8 swap in '96 tracker
« Reply #1 on: September 20, 2012, 03:30:11 PM »
With a custom drive-shaft you should be able to. Not sure how well it will hold up to larger tires though.  One problem you will have to work around is getting the exhaust to fit.  But without a front diff you shouldn't have to worry about oil pan clearance.
« Reply #2 on: September 21, 2012, 12:01:09 PM »
are there any suggestions for a tranny/t-case combo? I read somewhere about using a samurai t-case to a t-5 or c4 tranny??
« Reply #3 on: September 21, 2012, 02:15:57 PM »
I would just stick with the Samurai t-case.  It's there and a divorced t-case so you just need a custom drive shaft out of your transmission that goes to the Samurai flange.
« Reply #4 on: September 21, 2012, 02:38:40 PM »
Sounds good, my 16v is already past the 230K mile marker on the ticker and starting to show signs of its age. I figured with an all new setup and a bit more power to turn the 35's, it was time to lay the 16v to rest. The 4x4 conversion probably won't come till later. I've got a lockrite locker on the way for the rear end so i'm excited for the end result
Offline ToyYoda
  • 226
« Reply #5 on: September 24, 2012, 06:59:13 PM »
Have you considered the weight over the front end ?  Off roading can/will be affected big time. Just replacing the springs isn't going to change the negitve that 3X the motor weight will do to your Kick/Tracker. Might want to look into it. ;)
Offline Jluck
  • 1389
  • 40
« Reply #6 on: September 25, 2012, 06:40:07 AM »
Just because something is cheap don't make it a good swap candidate. There has been and will be many V8 Suzukis out there, most heading to scrap shortly after. I have watched wonderful wheelers turn to embarrassing,plowing crap with lots of noise from under the hood after a V8 transplant. YMMV.
My .02 and worth what ya paid.
« Reply #7 on: September 26, 2012, 10:59:17 AM »
what recommendations would you make to the suspension?
