fuel injection to carb?
  • 2023 Views
Offline gotzuk?
  • 18
« on: May 13, 2010, 06:43:14 PM »
anyone on here taken a fuel injection and changed it to carb? is the fuel pump the same on both? thanks
  • 6594
  • 68
Re: fuel injection to carb?
« Reply #1 on: May 13, 2010, 08:18:51 PM »
Fuel pump pressure would be different.
We need more specifics to answer your question better. Like, what vehicle?
Offline gotzuk?
  • 18
« Reply #2 on: May 14, 2010, 03:59:46 AM »
ive got a 1994 samurai fuel injected. the other one is a 1988 samurai.
Offline jow003
  • 403
« Reply #3 on: May 14, 2010, 07:42:17 AM »
if you wanna sell the fuel injection system (if it will work on my 87 sami) ill gladly take it off your hands ;D
BUY MY STUFF!! pm for details
87 Samurai...
5" SPOA/OTT -RRO
1.5" leaf springs-OME
RUF conversion-Trail Tough
1" shackles
33x1250x15 MTZs
15x8- DC-2s
  • 6594
  • 68
« Reply #4 on: May 14, 2010, 07:46:14 AM »
Yeah, that's a great system on your Samurai... I'm surprized you'd want to change it out. But if you do, you'd want to get a distributor from a carb'd model, a fuel pressure regulator that regulates  at around 1 to 5 lbs, and the intake / carb assembly off of your donor... You also need all the wiring because the carb is computer controlled...  YOu could do a Weber and then you wouldn't need the computer and wiring but you'd still need the intake from the carb'd Samurai.
FWIW: there really is no benefit to doing this. It would be a big step backwards in performance and reliabilty.
May I ask why you are entertaining this idea?
