Battery Box
Battery Box
RJkick
634
5
Battery Box
April 26, 2019, 01:17:23 PM »
Anyone build or buy a battery box? I have a 92 4dr with the EDSE kit so water comes up through the strut tower and my battery gets corroded. I thought maybe a battery box to keep it dry
92 Sidekick 1.6L 16v Calmini\OME 4.5" lift 3" Body Lift OME962 springs in front w\.75" spacers OME955 in rear w\1.75" spacers Extreme Duty Strut Eliminator kit and rear ProComp MX6 Shocks 31X10.50 BFG A\T Thorley Header 2" exhaust Calmini front truss bar and stabilizer and skids Custom Bumpers and Rock Rails Limit Straps
fordem
4334
170
Re: Battery Box
April 26, 2019, 01:33:53 PM »
What sort of battery do you have? Automotive batteries generally do not "corrode" because they get wet, so I want to think what you're looking at is more likely to be a defective battery.
RJkick
634
5
Re: Battery Box
May 02, 2019, 02:11:50 PM »
That may very well be - I took a look and it was 7 years old - I was shocked and then replaced it and added the brass connections so I should be good to go
thanks
