spoa lift on a 92 sammi
Jakezuki
21
September 25, 2012, 11:24:00 AM »
hopeing i can get an answer on welding perchs onto axle do i have to twist the axle at all or straight on top and any other tips would help thanks
ecoast
509
8
You tube my space, and I'll google your yahoo
Re: spoa lift on a 92 sammi
September 25, 2012, 12:38:47 PM »
New should be parallel to old.
Then grind the old ones off so it looks nice/won't hang up (optional)
Drone637
8121
116
Evil Cow
September 25, 2012, 02:08:37 PM »
Or just get some of the self-aligning pads that Sky Manufacturing makes and take the guess work out of it:
http://www.lowrangeoffroad.com/index.php/suzuki/samurai/suspension-parts/sky-hd-sky-self-aligning-spring-over-axle-pads.html
Jakezuki
21
Reply #3 on:
September 25, 2012, 04:22:46 PM »
thanks is there anything elsee i need to do this other than perchs and new bushings
tombstone
212
Reply #4 on:
September 25, 2012, 05:18:13 PM »
YES!!You will need to square away your steering,drop pittman OR drop drag link should do well.Oh and longer shocks too!
Drone637
8121
116
Evil Cow
Reply #5 on:
September 25, 2012, 05:26:28 PM »
You can cheat on the shocks and just flip your spring hangers around. All though at that point you should probably extend your bump stops a bit longer.
I'm a big fan of the Sky Stage 2 lift. It gives you everything you need for a SPOA. Longer brake lines, pads, drive-line spacers, and an Over The Top steering setup.
http://www.sky-manufacturing.com/new/detaproduct.php?id=92
tombstone
212
Reply #6 on:
September 25, 2012, 05:30:19 PM »
True about the "cheating"....!!
