i need advice on tire size for my lift!
  • 7 Replies
  • 3233 Views
0 Members and 92 Guests are viewing this topic.
Offline ogibson
« on: November 21, 2010, 08:31:12 PM »
i have a 87 sammy with a spoa yj lift and front rear and tranny is geared low what is the biggist tire i could put on it? thx
'87 sammy
Re: i need advice on tire size for my lift!
« Reply #1 on: November 22, 2010, 07:50:47 AM »
I would say 33" max
Offline ogibson
« Reply #2 on: November 22, 2010, 03:46:24 PM »
thx man i appreciate it
                         -gibson
'87 sammy
Offline tuxblacray
  • 20
    • Tuxblacray Photos
« Reply #3 on: November 22, 2010, 04:44:47 PM »
Depends on what shackles you choose.... and the number of leaves you retain in the spring pack. It is possible to run 33 - 38 if you choose too.
stock shackles
long shackles
reverse shackles
bone shackles
missing links
I am pretty sure if you run yj's / missing links / & a 4 spring pack 34's will fit with ease and comfort.
        Tux...
Offline Medford
  • 184
« Reply #4 on: November 28, 2010, 11:09:17 PM »
Geared low.  I would say 30's tops.  Mine is geared stock and 30's are sucky on the road.  I wish I was geared low for off road too.
96 Tracker LSI, 2.5" Pro Comp lift with cooper 30X9.5 STT tires.  A bit of trim and beating to make the front work.
Offline jow003
  • 403
« Reply #5 on: November 30, 2010, 05:48:09 AM »
my stock gearin pushed my 33s around ok around the neighborhood but i didnt take it on the hwy or anything.  for almost all offroading you'd have to put it in 4lo id imagine.
BUY MY STUFF!! pm for details
87 Samurai...
5" SPOA/OTT -RRO
1.5" leaf springs-OME
RUF conversion-Trail Tough
1" shackles
33x1250x15 MTZs
15x8- DC-2s
Offline my996duc1
  • 222
« Reply #6 on: November 30, 2010, 07:57:18 AM »
a few variables involved ...
are your fenders cut or stock ?
what do you mean by "tranny is geared low" and how low is your low ?
most guys have lower gears in the ring and pinion and/or the t-case.
what engine are you running ?
Here are a couple of online calculators for gearing, although they don't take into account if you are running a 60hp engine or a 100hp engine.
http://www.lepayne.com/gears.html
http://www.grimmjeeper.com/gears.html
Keep in mind when gearing/tires what you plan on doing with it (off-road or on-road or both)
Mine took a couple times of gearing to figure out the way I should have done it in the first place.
I am still trying to wear out a set of 31" tires so I can go to a 33" tire.
« Last Edit: November 30, 2010, 07:59:19 AM by my996duc1 »
1987 Tintop / 1.6 16V ps & ac / 6.4 t-case Twisted TT / 4.30 R&P Hybrid rear / Double Tough axles / Shrockworks all around / ARB f&r / Mighty Kong & TT full skid / DS disconnect / CV shafts f & r / YJ missing links f & r / Petroworks tintop cage / 15 gal Tank / 31" x 12.50 Pro Comps
« Reply #7 on: November 30, 2010, 08:48:00 AM »
One thing to remember also with bigger tires, is that they weigh more than
smaller tires. The combined weight of 1 of my 33" LTB Swampers and the
rim is about 60 Lbs, and makes a stock wheel and tire feel like a toy.
What I'm getting at is the rotational mass, like adding a heavy flywheel
to an engine, makes it rev slower, and 4 heavy rotating tires, in addition
to the lever action of a tall tire will make your little motor feel really sluggish,
gears help reduce the tall tire affect, but you still have a much heavier mass
spinning under you, so no amount of gearing, even if it specs out as it would
if it were stock on stock rubber, will get back the pep it once had, for that to
be back takes more torque, like a bigger engine or boosting the engine you have
