mixing Diff parts
  • 1571 Views
Offline talonxracer
  • 1284
mixing Diff parts
« on: February 18, 2012, 03:21:08 PM »
I have a 8 tooth pinion from a 5.12 gear set and a front/rear thirds with 4.30 gears(43 tooth ring(still under the truck)), can I combine the 5.12 pinion and the 4.30 ring gear to have a working 5.38 gear set?
Offline mrhawk
  • 130
  • I Love ZUKS
Re: mixing Diff parts
« Reply #1 on: February 18, 2012, 11:37:18 PM »
No. They are cut very differently so they won't mesh.
« Reply #2 on: February 19, 2012, 06:29:42 AM »
Technically speaking the ring & pinion are not a part of the diff - the diff would be the piece that the ring gear fits over & bolts onto - essentially a housing containing a pair of side gears and 2 or 4 pinions - and you can swap the pieces from one diff to another.
You can also swap a ring & pinion from one diff to another, but mixing ring & pinions is a major no-no - even if they are the same ratio - when they leave the factory they are lapped to create a matched gear set, and if you swap you're likely to end up with a noisy gear set.
