86 samurai with 215's
  • 1684 Views
« on: January 26, 2011, 09:49:21 PM »
bought an 86 samurai with stock supension and it has 215's on it. I have about 2" of daylight between tires and fender flares and wanted to know if the spring over kit is going to raise it to much? Are the tires going to look to small?
Offline mike5721947
  • 545
Re: 86 samurai with 215's
« Reply #1 on: January 26, 2011, 10:09:43 PM »
a spring over with stock leafs gives 5 inches if i remember right... so add 5 inches to that... ya they are going to look to small. (take a jack under the frame under the door and start jacking till you lift that side 5 inches up from where it is now. (wheels should still be on the ground) that will show you what it will look like
31" kumhos 3inchs of lift.
Offline doughboy0379
  • 290
  • 9
  • Blinker fluid is free so use it........
« Reply #2 on: January 27, 2011, 12:56:15 AM »
X2
86 Samurai, SPOA, 3" HD leaf springs, 31/10.5/15 Big-O XT Tires, K&N Air Filter, Doug Thorey Header, more coming when I find the funds :)
« Reply #3 on: January 27, 2011, 05:08:05 AM »
Ok, the tires are new so maybe I'll wait until they wear down a bit and then lift/tires at once. Maybe just shackles and new springs???
Thanks guys
Offline Jluck
  • 1389
  • 40
« Reply #4 on: January 27, 2011, 07:46:43 AM »
you must have carried your forum name over from another forum? "fasterthanyou" and you have a Sammy :laugh:. hummm......
« Reply #5 on: January 30, 2011, 08:30:50 PM »
Are the tires rubbing?  They shouldn't be....I have ran 225/75s on aftermarket wheels on a stock samurai and didn't have any problem with them rubbing.
