How Much HP till Rearend Pop's?
  • 1442 Views
Offline ender06
  • 74
« on: January 21, 2012, 10:20:17 PM »
OK so like it says, how much HP and tq till the stock Rearend POPS. 95 tracker 4x4. I'm in the process of dropping in the 4.3L/4L60E and I don't want to have to swap axels. With what little work on the 4.3 I have done I'm guessing its around 220hp crank. I'm sure it can handle this for a good while but I'm guessing a Turbo or wet shot would be making +/-350hp and probably pop real quick. What do you guys think and what experience do you have with these? Thanks guys.
Offline mrfuelish
  • 2862
Re: How Much HP till Rearend Pop's?
« Reply #1 on: January 22, 2012, 09:47:18 PM »
You Tell us, Just drive it till it breaks and then go with a ford nine inch.
« Reply #2 on: January 23, 2012, 10:00:51 AM »
It really depends on how you use the extra hp.  My 2.7 stats are 185 hp, and lit up 30x9.5x15 when I wanted to, and was tested frequently at first (I don't test it very much now).  I am going to 33's and hope to continue with a nondestructive combination.  You can bust equipment with 36 hp and jamming through obstacles, it will be easier with 220 hp.
Offline Boxcar
  • 936
« Reply #3 on: January 29, 2012, 04:16:33 PM »
ONE GOOD HOLE SHOT...and your done..Look for a 44 from a cj5 71 and later / close to the same width will handle the hp / not a tough swap / readily available....Boxcar...
God Bless
Offline ender06
  • 74
« Reply #4 on: January 29, 2012, 05:07:20 PM »
Thanks boxcar. That's awesome info to keep in storage! Thank you!!
Offline Boxcar
  • 936
« Reply #5 on: January 30, 2012, 07:55:26 AM »
Your welcome...Hey they run them in the Viper , The vette, Ford 1 tone fronts, Jeeps , etc etc etc . The list is long and impressive...Nice short pinion (unlike the 9") pre 71 CJ5 will be offset to the passenger side post 71 will be centered .
71 and later will also have the 11 brakes... I recomend trussing the tubes for anything over 35s....
A couple of years ago I compiled a list of lengths corresponding to the rigs they were run in . I will look for it and post later
...Boxcar...
God Bless
