steering on straight axle sidekick
  • 8 Replies
  • 3573 Views
Offline S.Sidekick
  • 378
  • Suzi Suzuki
« on: December 01, 2009, 03:40:38 PM »
hey when setting up the steering on toyota axles what kind of steering should i use.
Offline biker
  • 730
  • It's a sickness I tell ya
Re: steering on straight axle sidekick
« Reply #1 on: December 02, 2009, 06:14:38 AM »
I believe Lowrange has a kit to adapt the Sidekick steering to Toyota steering
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
  • 6594
  • 68
« Reply #2 on: December 02, 2009, 08:18:42 AM »
This is a pretty easy one... You keep the stock Sidekick box and get high steer for your Toyota axle. When you're talking to the person you getting the high steer from (Recommend Sky manufacturing) tell them what you are doing and they can make the draglink with appropriate tie rod ends. BOOM! You're done.
Hope this helps, Eric
Offline S.Sidekick
  • 378
  • Suzi Suzuki
« Reply #3 on: December 02, 2009, 02:09:37 PM »
ya thanks i found out that the high steer would work with my steering box.  But that the tie rod that goes to the box would needed to be drilled out, but your saying that they would make it fit my rig without drilling?
  • 6594
  • 68
« Reply #4 on: December 02, 2009, 02:31:35 PM »
Yes.... Give 'em a call.
Offline Snorkeld_Zuk
  • 94
  • HAMMER DOWN!
« Reply #5 on: December 07, 2009, 09:49:32 PM »
yes, sidekick box will work, however, its preferable to move the axle a bit forward for better clearance on the back of the fenderwell and better wheelbase. Also the sidekick box has a shorter throw than the yota box. By bud has yota axles and sidekick box on his sammy, and it doesnt turn it all the way to the bumpstops. Yes Sky is the man to help ya on this tho. But I recommend the toyota IFS box. Its stronger, and has the throw needed for the axle.
88 Samurai: (White Zuk) Lifted, locked, geared, caged, etc
88.5 Samurai: (Red Zuk) Project pile
Offline S.Sidekick
  • 378
  • Suzi Suzuki
« Reply #6 on: December 10, 2009, 06:07:12 PM »
went and saw poopmans, not doing the YJ swap.  trailtough here i come :laugh:
Offline jawman
  • 406
  • 1234
« Reply #7 on: December 21, 2009, 09:29:38 PM »
say if I move the front axle 4'' or 6'' or even more do I need to relocate the box or can it be in the same spot with the axle pushed forward?
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Offline Amilla
  • 1076
« Reply #8 on: December 24, 2009, 05:39:30 AM »
You would have to move the box up with the axle. Have the steering box in front of the axle.
Amilla
