Steering Rack Question
  • 2895 Views
Offline 3stagevtec
  • 204
  • killing two stones with one bird...
« on: September 14, 2011, 03:26:32 PM »
The steering rack on my 2002 Grand Vitara sprung a leak at the top where the steering flexible shaft connects to the top of the unit. This is the 1st time I am opening this thing up..
Rack leaks right around the seal at the top where the steering shaft connects to it.
Another angle, metal hard lines removed.
Pulled the head out and noticed a greasy substance..
Better view.. Does it really have grease in there? I though the steering fluid did all the lubrication..
More 'grease' seen down in the rack..
Is that really grease or is it sludge build up? I have a 2003 model and this is the original rack..
Re: Steering Rack Question
« Reply #1 on: September 14, 2011, 05:07:12 PM »
Yup - that's grease - fluid doesn't flow in that area.
In the rack itself the fluid flows between the two unions - one at the passenger end and the other midway down the rack - that's actually where the power assist is done, and there's a control valve section in the "head" that you took off.
I don't know if you're aware of this - but Suzuki considers the rack assembly to be "element replace" - you can change the rack ends, the boots, and the rod ends, but for anything else, you replace the entire unit.
Offline 3stagevtec
  • 204
« Reply #2 on: September 14, 2011, 05:53:23 PM »
Ok, that's makes sense now.. I will clean and reapply some synthetic grease before reassembling.
I am aware Suzuki doesn't sell parts for the steering rack.. so I am hoping to find used parts in good condition to repair mine.
The cost for a new rack...
« Reply #3 on: September 16, 2011, 07:34:32 AM »
I would think it's a simple seal, otherwise just
get a used wrecking yard replacement.
Offline talonxracer
  • 1284
« Reply #4 on: September 16, 2011, 07:53:35 AM »
More and more manufacturers are making components as non-rebuildable and disposable. This is to make more money and force people to buy parts from the manufacturer/stealership rather than a local mechanic servicing the component.
Offline 3stagevtec
  • 204
« Reply #5 on: September 17, 2011, 07:43:46 PM »
I got a used seal and it was a simple change. Popped the old seal out and carefully pressed in the 'new' one.. Very basic tools were required to get the job done, saved me quite abit and the new seal is holding out fine so far..
« Reply #6 on: September 18, 2011, 12:43:42 AM »
That is good news, good job
