Toyota IFS (paging Mr. Hagen)
  • 94 Replies
  • 28304 Views
Offline Mikerpm4x4
  • 2875
  • 12
  • Redline... all the time!
    • www.rpm4x4.com
Re: Toyota IFS (paging Mr. Hagen)
« Reply #15 on: May 12, 2005, 11:24:56 AM »
Honestly swapping the toy diff into the front has never crossed my mind. I do not know what that would entail.
Mike
Offline explosivo
  • 3157
« Reply #16 on: May 12, 2005, 11:27:16 AM »
omghi2.us[/url]
Offline Mikerpm4x4
  • 2875
  • 12
    • www.rpm4x4.com
« Reply #17 on: May 12, 2005, 11:34:02 AM »
http://www.pirate4x4.com/forum/showthread.php?t=318480 :o
This is not the same thing. This does look interesting but not the same.
Mike
Offline Mikerpm4x4
  • 2875
  • 12
    • www.rpm4x4.com
« Reply #18 on: May 12, 2005, 11:35:15 AM »
Offline explosivo
  • 3157
« Reply #19 on: May 12, 2005, 12:00:46 PM »
:P
omghi2.us[/url]
Offline Mikerpm4x4
  • 2875
  • 12
    • www.rpm4x4.com
« Reply #20 on: May 12, 2005, 12:06:24 PM »
:P
Offline Mikerpm4x4
  • 2875
  • 12
    • www.rpm4x4.com
« Reply #21 on: May 12, 2005, 12:07:42 PM »
 ;DIm smiling cause I have no idea whats going on! ;D
Offline explosivo
  • 3157
« Reply #22 on: May 12, 2005, 12:09:52 PM »
;D I'm smiling because I'm going junkyard hunting tomorrow, and then I'll find out how feasable the Toyota IFS swap is for myself ;D
omghi2.us[/url]
« Reply #23 on: May 12, 2005, 12:58:24 PM »
Dude, talk to mike and stan and get some details about stans set up. It's awesome!!! He hammered the &*^&^ out of it all weekend and the IFS Kicked ass 8) Definately worth the work ;)
Offline 37kicker
  • 319
  • 97 tracker 9inch front and rear on 40" pitbulls
« Reply #24 on: May 12, 2005, 03:15:15 PM »
thanks for answering those ??'s for me mike  ;D i got in late, more r&d on new projects. i dont have any good pixs yet. hope mike answerd ??'s if not get back to me. stan
Offline whitfield
  • 633
  • 4-dr Kick on 34's
« Reply #25 on: May 14, 2005, 01:44:41 AM »
You guys are making my head hurt again  ???.
1. Widen front end.
2. Clearance the spindles (Top to fit)
3. Pass side stub will need to have the toy flange welded on.
4. Drivers side stub will use a bolt on adapter?
5.  Install 86 & up CV's with shafts (Right on right / Left on left?)
6.  Use Toyota IFS Lockouts  (Is the Suzuki & Toyota Asian lockout bolt pattern the same)?
« Last Edit: May 14, 2005, 01:46:58 AM by whitfield »
Offline Mikerpm4x4
  • 2875
  • 12
    • www.rpm4x4.com
« Reply #26 on: May 14, 2005, 02:08:08 PM »
1. Widen front end.
Questions 1-6 = yes ;D
Mabey Stan can verify this but i belive toy shafts are the same length on both sides.
Mike
Offline whitfield
  • 633
  • 4-dr Kick on 34's
« Reply #27 on: May 15, 2005, 12:47:22 AM »
Thanks!     ;) 8) :D ;D
Mike
THe IFS Yota front diff is big, heavy, and ugly.  Mine also has the center vacuum disconnect.   It is so big I'm not sure their is room.   A hybrid Hilux rear center up front would probally be easier.
« Last Edit: May 15, 2005, 12:50:36 AM by whitfield »
Offline 37kicker
  • 319
« Reply #28 on: May 15, 2005, 12:05:12 PM »
the toy cv's are the same length. you need toy lockouts because the outer axle stub is bigger. i thought of the toy diff. but the gear selection was limited.        stan
Offline Natebert
  • 1098
« Reply #29 on: May 15, 2005, 12:46:27 PM »
I don't know.....
I saw Stan pull Ross's Sammy and the front wasn't even on the ground.  How cool can a suspension be when it isn't even on the ground half the time?
;D
~Nate
