Toyota vs Sidekick Power Steering Samurai
  • 8 Replies
  • 5855 Views
Offline S.Sidekick
  • 378
  • Suzi Suzuki
« on: August 28, 2012, 07:48:44 AM »
Hey all, I wanted to get some opinions on adding powersteering to my Samurai. I already have Over the Top steering, but I am wanting to give my arms a break. I am running 33's and locked in the front.  Still running Samruai axles, but what setup did  you like most, Toyota or Suzuki? Pros/Cons. Thanks for the help!
Jon
Offline djjiz
  • 48
Re: Toyota vs Sidekick Power Steering Samurai
« Reply #1 on: August 29, 2012, 07:28:36 AM »
I run a tracker pump with a locker and 31"s and yes, it does work, but I want more steering.
I'll kiss your moms dildo for $10
Offline ecoast
  • 509
  • 8
    • East Coast Canvas
« Reply #2 on: August 29, 2012, 11:32:03 AM »
as above, but 33x12.50
I shimmed the pump as well...
I'm about to tap the sidekick box and go partial hydro = <$100 bucks...
Offline crewcabrob
  • 348
« Reply #3 on: August 29, 2012, 12:55:26 PM »
Do you guys suggest running power steering with a smaller size like 31" tires or just when you pass that mark?
Rob
Offline S.Sidekick
  • 378
  • Suzi Suzuki
« Reply #4 on: August 30, 2012, 11:33:29 AM »
ok... my only consideration is I plan on going Toyota axle's in the future... so toyota made more sense, but sidekick's are a dime a dozen... I am just waiting for my ARB to blow up in the axles then Yota time!
Offline djjiz
  • 48
« Reply #5 on: September 11, 2012, 03:02:09 PM »
Rob
I won't drive without it.
« Reply #6 on: September 11, 2012, 06:52:10 PM »
Rob
On one of my samurais, I only run 29s and an open front, and I still added PS to it.  Definitely worth it, no matter what size tires you run.
Offline locjaw
  • 2045
  • 22
« Reply #7 on: September 12, 2012, 06:37:38 AM »
i have a trail slayer(toyota axles) and i have found my P/S to be more than sufficient, that being said, these steering systems are sensitive. my father has a 2+2 calmini kit on his and it steers like a tank. i think the pumps get old and worn and dont pump the same PSI as when new. locking the front axel will make ANY steering system difficult, even full hydro. there are just too many opposite forces working against each other.
so
my opinion would be......suzuki !!
Offline Merlin93
« Reply #8 on: October 06, 2012, 09:13:42 AM »
Quote from: Skyhiranger
  ... I only run 29s and an open front, and I still added PS to it.
X2!
I'm also on 29's (but just one Samurai here), and Sidekick PS made a huge difference.  Now the wife can and will drive it too!
I wish I'd done it sooner.
