turbo theory 102
  • 35 Replies
  • 12586 Views
Offline bandit86
  • 1641
  • elv8rguy
turbo theory 102
« on: December 16, 2003, 12:18:27 PM »
the electric leafblower is fed into the tbi.  Suppli will have to be through a 1500 watt power inverter and a cap on the battery to avoid sudden powersurges. squeese trigger, voila, you have boost.  lots off idle and low rpm, not so much at high rpm
Offline 87BlackSami
  • 191
  • http://www.quic kvwbug.4wdriver .com/
    • http://www.quickvwbug.4wdriver
Re: turbo theory 102
« Reply #1 on: December 16, 2003, 01:02:17 PM »
Believe it or not somebody beat you to it. There is also a company that takes electric motors with impellors and mount them in a tube. Then they sell it to kids that install it inline of the intake system. They say it does something but it can't be much.
locked,5.8:1 Tcase, 5.12's, 35x12.5Xterrain's, 4" BDS L/O, Ford towers, 5-8" shackles w/reverse, tracbar, Yota P/S, diffs capped, skidplates, onboard air, fabbed bumpers & shafts, Herculined, airhorns
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #2 on: December 16, 2003, 08:56:53 PM »
What if you had a leaf blower for each cylinder????
:P  :P   :P  :P  :P
96 Tracker
32 MTR's Warn 8000i
Offline 97TRAKIN
  • 600
  • Suzuki in Chevy clothing.
« Reply #3 on: December 16, 2003, 09:52:34 PM »
This is FAH! 87BlackSami, I saw those electric blowers on Ebay also. They were basically marine engine room exhaust fans/blowers.
« Reply #4 on: December 16, 2003, 11:03:41 PM »
I did some research into this a few years ago. You need a huge fan to pass enough air, the power supply would be in the region of KW, so you'd need around 100A to run it, which means bigger alternator, twin batteries and all that nonsense. You do need a big fan otherwise the fan will restrict air flow at higher rpm and loose power. Trouble is where does the power for the fan come from - yep the engine, anyone who runs a winch will know how much power it takes to run a big electrical load. Someone somewhere was claiming a 5% power increase, well I've seen bigger power increases from a change of oil and a clean of the spark plugs.
Offline bandit86
  • 1641
  • elv8rguy
« Reply #5 on: December 17, 2003, 09:42:03 AM »
exactly.  I was leaning towards 120 Amps, hence the 1500W inverter.  Some of theese blowers put out an advertised 20 mph wind, some advertise 400cfm.  You would not need extra alternators, as this would not run all the time, just like your starter motor, it would be there to get you out of a jam
« Reply #6 on: December 17, 2003, 10:06:46 AM »
What you need is a compressor, not just a blower, 400 CFM
20 MPH, uhh I dunno if it's going to do much for your trouble.
You need PSI and flow, it's called boost, and a leaf blower is
not going to have what you want.
Offline bandit86
  • 1641
  • elv8rguy
« Reply #7 on: December 17, 2003, 10:12:46 AM »
if someone would donate me a leafblower and lend me an inverter, i would pay for dyno
« Reply #8 on: December 17, 2003, 10:32:44 AM »
what about a gas powered leafblower? A backpack style you can lay on your roof (or hood) route the hose into your snorkel(if you got one)?
« Reply #9 on: December 17, 2003, 12:02:41 PM »
LOL, you guys are STARVED for power aren't you.
COMPRESSOR, not blower, it has to compress the
air, a turbocharger takes a high volume of air and
packs it together, that's why compressed air from
a turbo can be 300F temp, a leaf blower does not
compress, it just blows, like the heater blower in your
car, if you stop the flow, it will not make pressure, on
the other hand, if you block the flow from a turbo it
will compress up to 20-30 PSI, and burn you with the
300F hot air it compressing.
So who want's a Turbo Manifold for your zook, I'll build
it for $300 heavy construction, I have a flange for a 1.6
right now, just needs tubes put on it, and a good used
turbo for another $150, you add the other stuff like
intercooler, aww heck I'll make that too, another $200
So for $650 you can have your Turbo Zook, you add the
plumbing to get the air in, increase fuel and get the
exhaust out the back.
Any Questions ???  I take Pay-Pal  ;D
Offline bandit86
  • 1641
  • elv8rguy
« Reply #10 on: December 17, 2003, 01:28:52 PM »
how about twin gas leaf blowers?
Offline ksa421
  • 382
« Reply #11 on: December 17, 2003, 06:30:47 PM »
If I had the money i might take you up on that turbo if bandit didnt want it. Does it affect you fuel economy at all? Are there any negetives to it? How much more power did you get? Thanks
Jacob
« Last Edit: December 17, 2003, 06:31:23 PM by ksa421 »
« Reply #12 on: December 18, 2003, 02:11:28 PM »
fuel economy is down 3-5 mpg depending on the
weight of your foot. power about 115 Guess |removethispart|@ 3 PSI
boost, Negs, uhh  getting it smogged
Offline CrazyCooter
  • 20
« Reply #13 on: December 19, 2003, 12:12:18 PM »
What are you doing for fuel while on boost? FMU? What turbo model from what vehicle?
« Last Edit: December 19, 2003, 12:14:18 PM by CrazyCooter »
Offline 1bigtracker
  • 3409
« Reply #14 on: December 19, 2003, 12:22:27 PM »
I would go turbo but hitting it with water would just blow up the turbo so that out.  I get the blower thing but it won't work.  you need forced induction.  if you could make a turbo powered by a 24V motor then you would be in bidness.  lata stu
  ÂÂÂÂÂÂÂ
