Water/alcohol injection!
  • 8 Replies
  • 2759 Views
Offline KJMac
  • 280
« on: July 01, 2011, 04:06:58 AM »
Bentparts,
Thank you for the info on the water/alc. Injection website, do it yourself water/alcohol injection.
It has part numbers for the items used from McMaster-Carr. Their is a list of nozzle size for HP range covered
You're engine falls in. If people running water/meth would share their setups, it would be very helpful and appreciated.
I know they used a solenoid for the water to shut off but for a lot les money a spring loaded check valve
Could be used. Thanks Bentparts!
Kevin
1994 Kick, 16v,header.2.5" exhaust,ported MAF,home made mufflers, K&N filter,5" lift with jeep LJ front springs on the rear and Ford ranger springs on front with 2 3/4 spacers,OME struts with 3" strut spacers,31/10.5 Hankook Dynapro MT on 15x7 black D's.
Offline tictac
  • 38
  • What's THAT noise now?
Re: Water/alcohol injection!
« Reply #1 on: July 01, 2011, 07:50:04 PM »
You might get away with using a check valve like we did with our old turbo dodges.  not high tech, but it works.  now we use devils own meth kit.  helps lower those temps and u can crank up the boost and make some power.  lol
94 Sidekick. Calmini 3" lift with EDSES. 2.0 engine swap (real soon) 😎
« Reply #2 on: July 02, 2011, 06:40:05 AM »
More boost yeah! ;D A check ball would work just fine and eliminate a lot of the extra crap I used on mine. I'd try that first, but make sure you get a GOOD one, that is don't scrimp here. You don't want the alc/h2o being sucked into the engine when the intake manifold is under a vaccume condition, which it is most of the time. Happy boosting!
Offline Jluck
  • 1389
  • 40
« Reply #3 on: July 02, 2011, 07:57:24 AM »
How about that link for the rest of us. :P
« Reply #4 on: July 03, 2011, 06:48:09 AM »
Offline tictac
  • 38
« Reply #5 on: July 05, 2011, 12:40:59 AM »
I still have some torbo dodge ones, give me an adress & ill send u one
Offline KJMac
  • 280
« Reply #6 on: October 30, 2011, 09:02:32 PM »
Do you still have some of the check valves you used? Thanks!
Kevin
Offline tictac
  • 38
« Reply #7 on: November 24, 2011, 07:32:41 PM »
sorry havent been on internet for over a month.  still have them if you need.
Offline KJMac
  • 280
« Reply #8 on: November 24, 2011, 11:39:32 PM »
Hey thanks for responding! I sent you a pm.
Kevin
