weber 40DCOE conversion
  • 37 Replies
  • 8748 Views
  • 6594
  • 68
Re: weber 40DCOE conversion
« Reply #15 on: May 22, 2011, 10:04:37 AM »
If you're going mudding like that, I would suggest against sidedrafts... The only way to make that work would be to build an airbox and pipe that to a filter in the cab. Do a google search to find images.
« Reply #16 on: May 22, 2011, 11:45:57 AM »
Eric i can do an airbox to side drafts aswell i will send you some more photos so that you can understand the parkour. (are you sure that there will be no incline and decline problem)
please help me to solve vacuum problem, than how to fit brackets and hwere i can find intake maniflold  (UK specially)
some suggestions for more power??? (no
please help me to sort out the problems... the competition is not to far away..
i will definitelly use a airbox and a snorkel. but first you need to help me to make this car powerful ???
  • 6594
  • 68
« Reply #17 on: May 22, 2011, 12:07:48 PM »
There may be a language barrier problem here....
Here's simple answers to what I think you are asking.
1 - Hawk Strictly Suzuki has manifolds for the DCOE carburetors.
2 - The inclines and bouncing will not be a problem.
3 - As pointed out in the tuning article, you'll need to have your mechanical advance on the distributor recurved because vacuum advance is not possible.
4 - baseline jetting is also called out in that article. You'll need to tune from there.
Hope that helps, Eric
« Reply #18 on: May 22, 2011, 01:26:39 PM »
thanks a lot Eric. i really appreciated. however i checked Hawk strictly suzuki for intake manifolts but i couldn't find any.
therefore:
1: can you please send me a link for intake manifolt
2: can you explain me how i can use brackets for carb (i want to safe them just in case)
3: i will purchase a better exchaust manifold and balanced cam shaft (any suggestions for cam shaft ???) and also any suggestions for another performance parts (like transfer case gears, ring and pinions, clutches??)
4: please expand your 3rd point (about mechanical advance and vacuum)
i know that i am causing trouble  :P :P but there is not enough skilled people in my country and they are against sidedraft carbs for offroad. therefore i need  to understand what we need to do to tell them
thanks for your precious advices. i really appreciated ;)
once i will start building i will post more pictures.
looking forward your reply ;)
« Reply #19 on: May 22, 2011, 01:37:19 PM »
also i found couple of places that sells airbox for twin 40DCOE but not in UK. do you have any idea.. just send me some links if you know any places that sells airbox ;)
thanks
« Reply #20 on: May 22, 2011, 07:19:21 PM »
For Hawk Suzuki you need to give them a call, a lot of what they sell is not on the web site.  As for the airbox, can't help you there.
Is there a reason you went away from the Fuel Injection and to the Carbs?  If you looking for more power a 2.0 or 2.2L engine swap may be a better path.
« Reply #21 on: May 22, 2011, 11:35:09 PM »
as you see in the pictures there is mud everywhere. i need to make everything waterproof. therefore less electrical staff means less problems.
also they cant modify efi here (i mean in a efficient way)
this is why i choose carb. also i reconditioned my engine therefore i wont change it with another engines... (i want to change but its like a dream')
« Reply #22 on: May 28, 2011, 08:04:06 PM »
guys can anybody tell me how to put mechanic advance on distributor ??? i am unskilled to do this :( what about the fuel regulator ?
« Reply #23 on: May 29, 2011, 10:26:33 AM »
The distributor has a mechanical advance mechanism and a vacuum advance mechanism. You need to lock up the vacuum advance mechanism somehow and then modify the stops on the mechanical advance so it can advance furthe., To get the correct rate of advance you need to experiment with the spring ratings.
« Reply #24 on: May 30, 2011, 11:44:03 AM »
thanks for reply... what about the 45DCOE ?? is it going to be too much for 1.6 vitara or shall i try ?? another question is which one is better for torque and acceleration.. i dont need increase in top speed just torque and acceleration. therefore maybe dual twin carb is not useful for me :S ??
may be i should go for one 40 or 45 DCOE instead of dual. do you have any suggestionsexcept cam shaft and exhaust manifolt change for more performance ??? (i will get rid of catalzor aswell)
lets be interesting lol. can i convert my 1.6 8 valve vitara to 1.6 16valve (but carb again)
« Reply #25 on: June 02, 2011, 08:41:12 PM »
i am looking forward your reply guys.
again asking the question:
how can i change 1.6 liter 8 valve (carb) vitara to 16 vale (carb) ??
« Reply #26 on: June 06, 2011, 09:38:51 PM »
cmon guyyysssss
« Reply #27 on: June 06, 2011, 09:58:55 PM »
16V engines don't have carbs here, so nobody really knows.
I would suggest you do an injected 16V and you won't have
any more drive-ability problems, but you will need all the parts
from a donor vehicle, and it can be a big project if you can't do
the work yourself it could cost a lot of $$
Offline KevinH
  • 19
« Reply #28 on: June 07, 2011, 12:43:11 PM »
the camshaft makes the engine, not the carb/carbs. You will never be able to tune/jet dual 45's very well on a 1.6 for low end torque, even dual 40's would be pushing it. I would think a single 40 would be fine and still be good for up to 6000rpm, plus it would be much easier to jet and tune, no balancing between the 4 throats, and there would be no hassle with throttle linkage and associated adjustments. I know there is float bowl mods that can be done on the triple and double downdraft Ida's, Idt's, and Ids's to prevent starving the main jet circuit during hard acceleration and cornering, these might apply to the DCOE side drafts as well, check out the porsche 924 and 944 forums on various sites and see what the racers are doing to mod the float bowls on their side drafts, might help in making the carb a little more off road friendly.
Cheers
Kevin
Offline Jluck
  • 1389
  • 40
« Reply #29 on: June 07, 2011, 03:10:53 PM »
cmon guyyysssss
and don't get too frustrated with the speed of this thread. this question is really the opposite of what the huge majority of us on this side of the pond try to accomplish.
the way I see it...for off roading modern EFI is a boon. going back to carbs just doesn't make good since. there is still a distributor involved and both EFI and carbs need good clean air to operate. what is the real problem? water in injector connections? (use dielectric grease).
EFI is much more reliable at angles and fuel supply efficiency.
I am not trying to be a jerk or anything but as this thread goes on the real objective seems to get harder to see.
contrary to popular belief the US has almost every climate region of the whole rest of the world and very demanding off-roading is done here too and EFI seems to do the trick.
