Weber carbourator problems
  • 1566 Views
« on: November 04, 2012, 01:11:21 PM »
Cant seem to adjust it just right any tips or secrets to these things. my problem is hit a bump an it will kill out i can pull up my drive way an it will kill out. any help will help me out thanks.
Offline rascott
  • 669
  • 15
Re: Weber carbourator problems
« Reply #1 on: November 04, 2012, 09:45:18 PM »
perhaps the float is set too high.
uphill may pour gas into venturi, if this were the case. mabe bumps too.(?)
have you looked inside it before?
32/36 weber?
Offline Capt
  • 738
  • 28
« Reply #2 on: November 05, 2012, 09:02:28 AM »
Is It Really a WEBER?
Stock Hitatshi carbs will do this when the Metering & Shut off solenoid is going south.
It is a NON-REPLACEABLE part. Only option is to get a different carb.
Haven't heard of a Weber having this problem.
« Reply #3 on: November 06, 2012, 01:24:12 PM »
IT IS A 32/36 weber SO I DONT KNOW I HAVE HEARD I NEED TO BEND MY FLOATS
Offline rascott
  • 669
  • 15
« Reply #4 on: November 06, 2012, 07:29:59 PM »
i still think it would be worth opening it up and checking the float set.
you mentioned it cuts out going uphill?
