I am at the end of my build and am having some handling issues. I have a SPOA on stock springs, new Gabriel shocks on relocated lower mounts, an OTT steering kit from Lowrange and new 31" AT's. The steering damper is old but still dampens.
On pavement the truck doesnt want to return the steering wheel to center after a turn and need constant attention to keep it straight. It seems to want to grab and go in the direction of the side of the truck that is weight loaded, either from a steering input or change in road camber. I have been working with the toe in angle on the front end trying to correct this. As I apply more Toe in the on road manners get better but the offroad handling get worse. Currently it is acceptable on pavement and scarey on gravel.
I have adjusted the play out of the steering box but it still drives as if something is loose in the front end.
