Team ZWO - ZUKIWORLD ORDER - Salem, OR
  • 73 Replies
  • 62642 Views
Re: Team ZWO - ZUKIWORLD ORDER - Salem, OR
« Reply #60 on: October 20, 2011, 09:11:08 AM »
Not totally intentionally.  I jacked out the frame until the bolt holes lined up for the engine mount, then Luke welded in the bar while I was at work.  Its hard to tell what all was distorted.  It will work fine though.
« Reply #61 on: October 20, 2011, 02:43:43 PM »
The Geo symbol is crooked.  You need to get on that.
:D
« Reply #62 on: October 24, 2011, 09:25:30 PM »
Well things were going pretty well.  My trailer was organized and packed.  Trailer hooked to the truck.  Race car was clean and running good.  I had enough free time to play with a few things.
The steering hasnt been strong since the reservoir broke in a previous race and ran dry for a long time.  I decided to change out the pump.  To do that I had to remove the oil filter.  "Why not change the oil" I thought.  So I did.  With the old pump off I found that the steering pump bracket only had one of three bolts in it.  I scavenged some bolts off of a parts engine and installed them then put the whole thing back together.  I fire the engine up and test the steering.  Much better.  Check for leaks and find that my engine has suddenly started leaking profuse amounts of oil.  Somehow the work I did disturbed the oil pump gasket at a pressure galley thats very near the edge where the steering pump bracket mounts up.  I thought maybe the pump had cracked but I have it all apart and there doesnt appear to be anything amiss other than a deteriorated gasket.
Two days until I leave for the race and here is how it looks.
Offline Soupy
  • 206
« Reply #63 on: October 24, 2011, 11:58:15 PM »
You know,your getting to these things a little early. Maybe you could put it all back together in the trailer Friday night before the race... then you would have the benifit of the stress of a real deadline :)  After you put some of those parts back on I'm sure it'll run better. :)
BTW... I haven't brought it up in a while. Should do a Seafoam tuneup before the race. Why? Because I use Seafoam to fix everything :)
« Reply #64 on: October 25, 2011, 08:17:52 PM »
The Zukiworld Order race car will live to race another day.  I found that a bolt was missing that held the oil pump onto the block.  This had allowed a small leak and subsequent deterioration of the gasket.  The oil pump is back in and the car is running good.  I couldnt go for a test drive since I dont have any lights.  Hopefully that will go good tomorrow.
I guess its a good thing I found out now, rather than at a race.  This car has been full of missing bolts.  The more I look at it the more I find.  I think there must have been a previous owner that had no business being under the hood of his car.
« Reply #65 on: October 25, 2011, 11:42:13 PM »
The joys of other peoples work.  :)
  • 6577
  • 66
« Reply #66 on: October 26, 2011, 07:13:52 AM »
Each part that leaves is weakness leaving the system. Lighter, faster, less parts left to fail... this makes a statistically better vehicle, right? It's all by design.
Offline tdrrally
  • 42
« Reply #67 on: October 30, 2011, 02:36:49 PM »
how's going now?
Offline jesusno2
  • 16
« Reply #68 on: October 30, 2011, 10:41:10 PM »
Cool to see someone from close to my neck of the woods I'm just over the river in independence Or.
« Reply #69 on: October 31, 2011, 03:35:41 PM »
Just got back.  The engine ran like greased lightning all weekend.  1st place in five of six moto's.  The first race was a DNF.  My fuel hose flipped up on top of the foam in the fuel cell when I landed off a jump and I lost fuel pressure.  With some help from a track official it was missdiagnosed as a lack of spark so I towed it off the track.
« Reply #70 on: November 02, 2011, 11:40:16 AM »
The suspension looked a lot nicer then mine as well, again.  :)
We'll be right with you next year!
« Reply #71 on: November 02, 2011, 12:17:40 PM »
Good! I am ready for some good competition.  Watching your in-car video made me wish for more door to door action.
« Reply #72 on: November 02, 2011, 12:52:18 PM »
I'll get the other two moto's on-line later today.  :)
« Reply #73 on: November 02, 2011, 01:17:56 PM »
I got good video as well.  I will try to get the time to trim it and then upload it in the next few days.
