spare tire mount on a tracker... how strong?
  • 28 Replies
  • 7905 Views
Offline strvger
  • 95
  • Livin' on the edge... of the Great Northwoods !!
« on: June 12, 2006, 06:39:40 PM »
hi,  just put on some 235/75x15 tires and was wondering if the spare timre mount on the rear door of my 1991 Tracker 2 door hard top will handle the weight of a 235x15 tire on a steel wheel without breaking anytime soon.  the wheel is from a jeep and a little bigger/heavier than a stock trac-kick wheel.  is there a mod that should be done to reinforce the mounting points in the door?  this is my daily driver and i go 60 miles daily round trip to work and back. don't want problems during the rush hour or anytime really!
thanks in advance   :)
'91 tracker, 1.6 8v 5-spd, 1.5 in susp lift,  DT header and 2 in exhaust, 235/75 AT's on 15x7 Turbines, 1st prototype: Ibuiltbumpers.com trackick front bumper!,  other mods coming soon!
Offline derekj
  • 784
  • i'm the canadian guy eh?
Re: spare tire mount on a tracker... how strong?
« Reply #1 on: June 12, 2006, 07:36:05 PM »
my space tire carrier was all good with a 235 but about a month of rough gravel roads and a 31" tire on it the mount started to break. i welded it up to make it stronger and then it cracked inside the rear door so the spare is now in the back until i get a new roof rack.
derek
91 Sidekick jx
2" BDS supension lift
2" BDS body lift
1" Coil spacers
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #2 on: June 12, 2006, 07:57:52 PM »
Is there a fix for the spare mount and big tire problem?  My Tracker will soon be back on 31's but it just has an itsy bitsy 205/75R15 spare because of space and strength issues. :P  Better than nothing but not much...
Offline the_maplebar
  • 466
« Reply #3 on: June 12, 2006, 08:22:24 PM »
Here's a good fix for the tire carrier  ;D
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #4 on: June 13, 2006, 03:28:00 AM »
Heeeellllooooooo wind drag... :P
Offline ddevil
  • 155
« Reply #5 on: June 13, 2006, 03:54:44 AM »
lol, not like we're driving sports cars here though right ;D
'95 geo tracker 2dr 5spd soft top with 2" suspension lift
Offline RJkick
  • 634
« Reply #6 on: June 13, 2006, 12:58:06 PM »
That's great for a 2 door but what about a 4 door
I was thinking about a custom tube bumper with a notch to at least hold the 31" spare at the bottom of the tire.  That way the stock spare carrier would shoulder less of the weight
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #7 on: June 13, 2006, 03:19:45 PM »
Eh, I try to keep all the mpg as high as I can...a rack like that is just going to suck mpg away.
Offline TLCzuki
  • 64
  • Luvin my Suzukis
« Reply #8 on: June 13, 2006, 05:25:37 PM »
I made a homeade basket for the top of my trackick and my mpg dropped by about 3 mpg and it sounded like a huricane once i got above 40mph.
« Last Edit: June 13, 2006, 05:27:18 PM by TLCzuki »
Speak softly and carry a big stick!
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #9 on: June 13, 2006, 05:41:52 PM »
I've heard similar comments SO many times before...those racks look cool but unless you really, really, need the storage capability, they're just going to make your vehicle less fun to drive.  Worse mpg and more annoying cabin noise.
Offline Carnage
  • 2453
« Reply #10 on: June 13, 2006, 05:46:08 PM »
my 18 is mounted pretty well on my 4D
you just have to tighten the bolts a few times from when you put them on
(almost like rims/tires)
« Reply #11 on: June 13, 2006, 06:03:26 PM »
I modified my spare tire carrier to accept a 31" tire, at  the same time I did my bumper and gas tank lift. I sectioned it, raised the actual tire mounting point just high enough so it still fits in the wheel, and I beefed it up by gusseting all the corners. But even before that I've had that 31 on there for over a year without any problems. Lots of trail rides and plenty of rockin' at Paragon. I know the mounts are different between the ragtops and tintops, ( my parts car is a ragtop) maybe the tintop is stronger.
Offline strvger
  • 95
« Reply #12 on: June 13, 2006, 06:34:17 PM »
thanks for all the suggestions.  i think i might try to work on something from the bumper that would take at least some, if not most, of the weight off the tire carrier.
« Reply #13 on: June 13, 2006, 06:38:15 PM »
 :) Wow, twin tintops. They look like long lost brothers.
Offline ddevil
  • 155
« Reply #14 on: June 13, 2006, 09:31:00 PM »
yeah don't i feel like a tool, i didn't think of it in the mpg aspect.  back on topic, not exactly sure how the tire carrier is mounted(pretty green yet on trackicks) but would it be possible to just make a large metal plate(for on the inside of the door where the carrier mounts to) and mount the carrier through the plate to help dissipate the weight?
