spare tire mount on a tracker... how strong?
  • 28 Replies
  • 9618 Views
Offline suzukiboyoz
  • 194
  • Friends don't let friends ride a Yamaha
    • http://community.webshots.com/
Re: spare tire mount on a tracker... how strong?
« Reply #15 on: June 13, 2006, 09:56:54 PM »
This is my mod I did for fitting a 30" MTR
Or mod you bumper.
Calmini 3" Suspension Lift, Calmini Skid Plates, Calmini Rockhoppers, 30" Mud TYres, ARB Bullbar, Rear ARB Locker, Custom Sill Sliders, Rear Bumper and a lot more.
« Reply #16 on: June 14, 2006, 05:31:23 AM »
Sure, just remove the inner panel and you can get a look at how it mounts. The bolts go into weld nuts, so if you want to add a plate of some sort you would have to remove them first. Probably tear up the door doing it though.
« Reply #17 on: June 14, 2006, 05:34:09 AM »
Suzukiboyz, nice bumper, did you make that? If not who sells that?
Offline the_maplebar
  • 466
« Reply #18 on: June 14, 2006, 07:38:59 AM »
would it be possible to just make a large metal plate(for on the inside of the door where the carrier mounts to) and mount the carrier through the plate to help dissipate the weight?
I have always thought that the weight concern was more for the hinges of the rear door, not the  carrier getting pulled off of the door.  Which is the reason I posted a pic of an aftermarket bumper with tire carrier... of course everyone went off on the roof rack instead  :P  I was not suggesting that you put the spare tire on the roof.
« Last Edit: June 14, 2006, 08:31:14 AM by the_maplebar »
Offline RJkick
  • 634
« Reply #19 on: June 14, 2006, 11:21:34 AM »
Has anyone beefed up the hinges or is there a swap for hinges off another vehicle
I was not thinking of the hinges either
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #20 on: June 14, 2006, 03:39:47 PM »
The problem I've seen, on 2 door soft top Track/Kicks at least, is that the outer door skin tears as mentioned before.  My '93 and '90 both have that...and neither ever had anything other than a 205/75R15 OEM spare on them. :P
  • 466
« Reply #21 on: June 14, 2006, 03:58:23 PM »
In that case wouldn't a big(ger) washer inside the door at each of the bolts take care of the problem.  I wouldn't expect that you would need to add a metal plate.
Offline tOnKa TrAcKeR
  • 264
  • support our troops
    • Cardomain site
« Reply #22 on: June 14, 2006, 04:17:20 PM »
I had a 30inch superswamper on a 10inch wide steel wheel on the back of my tracker for 2 years and i have had a 33 back there for 6 months now and ive never had any problems.--no extra bracing or anything
Offline strvger
  • 95
  • Livin' on the edge... of the Great Northwoods !!
« Reply #23 on: June 14, 2006, 04:43:39 PM »
thanks guys for all the input.  it was the door skin i was most concerned about.  looking at all your pics and reading the comments, i think i will try to remove the rear bumper plastic and rig something that will mount to the bumper and support most of the tire/wheel weight.
or, i could just get one of those real fancy roof racks and hook a bunch of bungee cords from it to the tire to take the weight off!!    ;D
'91 tracker, 1.6 8v 5-spd, 1.5 in susp lift,  DT header and 2 in exhaust, 235/75 AT's on 15x7 Turbines, 1st prototype: Ibuiltbumpers.com trackick front bumper!,  other mods coming soon!
Offline ddevil
  • 155
« Reply #24 on: June 14, 2006, 06:26:52 PM »
how are you going to be able to use the rear bumper without hindering the door from opening unless you do some kind of swing down tire carrier thing?
milk
'95 geo tracker 2dr 5spd soft top with 2" suspension lift
Offline strvger
  • 95
« Reply #25 on: June 14, 2006, 06:56:37 PM »
well, not completely sure, but was thinking of something like a small roller like is used on small boat trailers.  depending on how i work the bumper, the roller would be fixed on it and when the door closes, the tire would ride up on the roller only about half an inch maybe.  just enough to give the tire some support.  that small amount shouldn't affect the door alignment much if any.  not sure til i get the plastic off the bumper to see what else might work.  open to all ideas at this point.       ???
Offline ddevil
  • 155
« Reply #26 on: June 14, 2006, 08:02:30 PM »
what i was thinking was maybe like how some tire carriers(like the one on my old pathfinder) swing out, make one that was hinged to the bumper that swung down and only latched to the door.  that'd probably take alot of the stress off eh?  probably be a bit of work to make though.
milk
Offline suzukiboyoz
  • 194
« Reply #27 on: June 14, 2006, 09:37:01 PM »
Yes made it up my self. Just have to mod the exhaust sticks out in the wide blue yonder now.
« Reply #28 on: June 15, 2006, 03:26:40 AM »
 :) Nice work, looks good and strong too.
