Wheel Spacer probs ANYONE HELP
  • 2162 Views
Offline JDMCRX
  • 1110
  • 02 Grand Vitra Pimp lol
« on: May 07, 2005, 06:35:30 AM »
Hey guys here is the situation
I got a 2001 Grand vitra and im putting the rims off my sidekick on to the gv but i need to get a 1" wheel spacer from ROCKY-ROAD i put them one temp and everything clears.
Here is the problem the center of the wheel spacer is too small by like 2-3mm i guess to center the wheel on the truck. Now the Sidekick has no lip and when u put the spacer on it it i uses the Lug nuts to center the spacer and wheel.
Im thinking of taking a grinder and just grinding the lip out of it and let the lug nuts center the spacer on the truck anyone im sooo stuck.
JOSH
01 GRAND VITARA
Re: Wheel Spacer probs ANYONE HELP
« Reply #1 on: May 07, 2005, 07:46:49 AM »
I can't see any problems with grinding it though a quick spin in a lathe would be preferable.
« Reply #2 on: May 07, 2005, 08:45:27 AM »
Thats how they center on the samurai (lug nuts)just make sure things are real clean and use blue loc-tight or green and torque to at least 55 lbs and let it set up for a day or more.
Offline JDMCRX
  • 1110
« Reply #3 on: May 07, 2005, 09:29:19 AM »
ok guys yeah i would rather lathe them but i go the truck all apart and i need the truck tomorrow so it should be good just grind them so they fit then the lugs nuts should center them
01 GRAND VITARA
Offline JDMCRX
  • 1110
« Reply #4 on: May 07, 2005, 10:18:39 AM »
Any more sujestions
01 GRAND VITARA
« Reply #5 on: May 07, 2005, 04:59:37 PM »
Quit talking about it and gether done.
