1.6 rebuild, sumpthin aint right...
mrdezyne
181
November 08, 2011, 07:04:21 AM »
Hey gang,
Buttoning up this 1.6 8v and I'm trying to put the timing belt on. I know, this thread has been done a million times and search. Well this is a bit different. I'm pretty sure I have the timing setup ok, my problem is with this freakin belt that came with my rebuild kit and a question about the tension pulley. Just need to verify that this IS indeed the wrong belt and I'm not just missing another loop over some other pulley or cog. Its just the Cam cog, crank cog, and tension pulley right? IF so this belt is way off and I'll just have it replaced and move on. Also it seems a bit wide for the crank cog. Anyone have a pic of how this all looks correctly done?
Also, this tension pulley seems to be a tad bit smaller than the one I pulled off of the motor. the one I pulled off was a black plastic style outer ring, not the thin metal ring that is installed in the pics (the new one) any input on that? ok to use, or the wrong one?
mrdezyne
181
Re: 1.6 rebuild, sumpthin aint right...
November 08, 2011, 07:09:02 AM »
looks like I'm about 8 teeth too long. 95 teeth for an 8v timing belt... but what about that pulley?
fordem
4333
170
November 08, 2011, 08:59:36 AM »
You may have the belt & tensioner pulley for the 1.3 DOHC there - that engine uses a longer belt and a smaller pulley.
mrdezyne
181
Reply #3 on:
November 08, 2011, 09:25:48 AM »
thanks, those will come in handy when I rebuild the stocker 1.3 then! I figured I just had the wrong parts, easy enough to fix. Late nights in the garage you start to question yourself on everything...
mrfuelish
2862
13
you must have a perception problem.
Reply #4 on:
November 08, 2011, 09:42:38 AM »
If you add another Cam to your stock 1.3 please post up some pictures, Thanks.
1987,1988,1988,1990 samurai's, 1953 m38a1, 1996 x-90,blue.1996 x-90 red.1994 2 door tracker. only Dead Fish go with the flow. No Hairy Nosed Wombats were ran over on the trail today. My ZUK is Xenophobic.
Skyhiranger
3734
122
I don't buy, what I can build
Reply #5 on:
November 08, 2011, 03:51:04 PM »
You have a timing belt for a 1.6 16V trackick engine. The 16V belts are 1" wide (vs. 3/4" wide for the 8V belts). The 16Vs also have 103 teeth, vs. the 95 teeth on the 1.6 8V belts.
I was thinking the tensioner pulleys were all the same for the engines though. As long as the diameter is the same as the old one (no matter how it looks physically), then you should be ok.
Last Edit: November 08, 2011, 03:53:46 PM by Skyhiranger
fordem
4333
170
Reply #6 on:
November 09, 2011, 04:32:45 AM »
And Sky is the winnah!!
I just realised that the part number can be seen on the back of the belt in the second picture - I plugged it in to the EPC and got back SE416 TIMING BELT (4 VALVE).
mrdezyne
181
Reply #7 on:
November 10, 2011, 07:28:07 AM »
New parts are being sent from supplier, timing belt, pulley, and valve cover gasket...
I just noticed the DOHC in that first reply, duh. Oh well, I have a new 16v timing belt and tension pulley if anyone needs one!
