Rhinoman, Are you saying that the HP and Torque curves will increase slightly at one end of the curve, but decrease from the other, if you advance or retarding the cam? ÂÂ
Theres more potential with a 16V as you can alter the intake timing independant of the exhaust but you always need to be a bit vareful as you will be reducing valve to piston clearances on the overlap
