1.6l 16v Valve timing?
  • 20 Replies
  • 11407 Views
Offline Fity
  • 49
« on: June 08, 2005, 02:34:28 PM »
On a 1.6l 16v there is two positions to line up the cam timing pulley onto the cam key as well as two timing marks on the outer edge.  I have always used the one that it was originally set on.  Does anyone know what the other setting is for?  Does it advance or retard the timing?  Which is better?  ???
Re: 1.6l 16v Valve timing?
« Reply #1 on: June 08, 2005, 02:54:53 PM »
The pin in the cam, where the pulley
goes, should be up, and the cam pulley
mark goes down, 1 tooth retard will move
the peak HP and torque up in the RPM
band, and advancing will move it down.
Best to put it back at the stock location
unless you are an engine guru and like
to tinker, like a Zaggy I know   ;)
Offline Fity
  • 49
« Reply #2 on: June 08, 2005, 05:09:08 PM »
Thanks Wild, but my cam pulley has two notches to locate it onto the cam and two marks for timing.  I am thinking that for some reason Suzuki has two valve timings for different markets.  Maybe it is only an Australian thing?  ???
« Reply #3 on: June 08, 2005, 05:29:09 PM »
Well which ever line up like I said
would be the ones I'm familiar with.
I suppose there is a posability that
the engines are slightly different from
here to there, but I don't see how too
radical of a change in timing could be
for 2 different markets, an engine only
runs well at about the propper timing.
I know that there are 2 marks, one has
an I and one has an E, I presume these
are intake and exhaust, but I'm not sure
« Reply #4 on: June 08, 2005, 06:44:14 PM »
give us a picture. maybe there are three marks, I, E and a dot? how many keyways does it have?
« Last Edit: June 08, 2005, 06:44:52 PM by mrfuelish »
Offline Fity
  • 49
« Reply #5 on: June 08, 2005, 07:13:19 PM »
mrfuelish, There are 2 marks "I" and "E".  "E" being the one that is standard. On closer inspection it looks like it may be slightly retarded.  I was guessing that it had something to do with other markets having better or worse grade fuels.
Wild, I have seen the same pulleys on Aussie 16v,Jap import 16v, Jap import Swift 16v.  I was assuming that they all had them.  :)
« Reply #6 on: June 09, 2005, 07:44:31 AM »
They do that for emissions here like in the state of california, look up a 1970 460 ford and then look up a 1974 ford 460 and look at the horse power diffrence, I think there trying to keep the gasses in the combustion chamber longer for a better burn but in turn loosing some horse power by doing so. you should be able to take a streight line across the key to the middle of the bolt to find the standard mark.
« Reply #7 on: June 09, 2005, 07:51:36 AM »
I was refering to the pin in the cam, or at
least that's what I was thinking of, it should
point up, in reality, it doesn't matter where
the pulley is, it matters where the cam is, the
marks on the pulley are for your convienience   ;)
« Last Edit: June 09, 2005, 07:52:41 AM by wildgoody »
Offline Fity
  • 49
« Reply #8 on: June 09, 2005, 01:57:35 PM »
I got the rule and protractor out and my guestimates are that the "I" mark will advance the cam by 1 Deg. :)
So going from what Wild said it will move the Torque and HP down.  Would it also change the peak HP and Torque?
« Reply #9 on: June 09, 2005, 03:28:01 PM »
As I understand it, the torque and HP
move, but remain the same, I think you
need a higher lift cam for more HP
Zaggy, you want to fill us in on this ?
« Last Edit: June 09, 2005, 03:28:32 PM by wildgoody »
« Reply #10 on: June 09, 2005, 11:37:17 PM »
Torque?
I reckon thats 41 teeth on that sprocket, the bottom isn't too clear. So 1 tooth is 180 degs/41 = 4.4 degs/tooth, Zaggy didn't report any real difference moving two teeth so I doubt if 1 degree will make any noticeable difference at all or even 2 degrees (is that 1deg at cam or 1 deg at crank?).
Altering the cam timing 'tilts' the torque curve, imagine what it looks like plottted on a graph. Stick a pin in the centre of the line and then push one end up and down a bit. Power = (torque *rpm)/n.
« Last Edit: June 09, 2005, 11:41:33 PM by Rhinoman »
Offline Fity
  • 49
« Reply #11 on: June 14, 2005, 12:34:40 PM »
Rhinoman, Are you saying that the HP and Torque curves will increase slightly at one end of the curve, but decrease from the other, if you advance or retarding the cam?  ???
BTW there is 40 teeth, so 4.5deg/tooth so my 1 deg might be closer to 1/2deg. :)
I would have thought that changing the timing would be more benifical then changing the cam timing by 1/2deg.  But I could be wrong. :)
Offline zaggy
  • 1134
« Reply #12 on: June 14, 2005, 05:53:18 PM »
Sorry I didn't reply earlier guys I've been buried at the aviation museum on a real special project.
    "Wildgoody" is right, playing with the cam timing typically only moves where the power is made not really how much you get. You have to alter lift and duration to change the amount of power. If you check out the thread where I reported on it it gives the data from real world testing.
   I haven't had a chance to look at a 16v lately (don't have one in the shop apart right now) but I believe mrfuelish is right in that it has to do with different emission requirements in different markets.
    By the by if you figure you're moving the cam timing 4.5 degrees guess again...because of the effect of the 2:1 ratio on the cam you are actually moving the cam 9 degrees...I have not played with the 16v so I would not recommend messing past factory settings for fear of damaging things.
    Search cam timing and hit the test results from my 8v experiments I think it will be help ful and I learned it all the hard way.
    Good call on this one "Wild" I thik you hit the nails right on the head with your responses.
Zag
ps
After getting a chance to look at the picture, I think the e/i refer to the intake and exhaust as someone else mentioned and I'll bet if anyone has the chance to check that the sohc 16v cam pulley is the same as the dohc cam pulleys and the settings are for which cam they are on with the dohc....
Zag
« Last Edit: June 14, 2005, 05:57:39 PM by zaggy »
« Reply #13 on: June 14, 2005, 06:02:28 PM »
moving the cam gear should not affect your distributor timing because you still time it by the crank, you can advance the timing untill it pings and them back off a little bit for top end or retard it for bottom end or towing running cheap gas ect.  the less weight your rig weights the more you can advance it and run a lower octain fuel.
Offline zaggy
  • 1134
« Reply #14 on: June 14, 2005, 06:03:11 PM »
Hi guys
    I found the info on the thread "pics of zaggy's engine" and was going to quote it here but messed up and ended up moving that thread to the top of the list.
Sorry.......but it's good info
Zag
