Re-Introduction & battery question
  • 46 Replies
  • 10274 Views
Offline lil_Truck
  • 1148
  • Eric Gardner
Re: Re-Introduction & battery question
« Reply #45 on: October 24, 2004, 09:33:27 AM »
I thought about going to dual batteries, but on one of the boards I was on at the time ???  There was a realy good discussion going on about the pros and cons of single vs dual batterys.
In a nut shell,
     A single battery may drain quicker but it also can be charged quicker.
     So in the long run if you go with two, you might be left with two dead batterys needing a long time to charge.
Anyway it was a long discussion and it convinced me to go with one battery and I'm planing on going with a higher output altenator.
P.S.  Another thing to do if your wenching, besides sutting off all electrical draws, is to put in something like a hand throttle where you can raise your RPMs up to 2000.  Your altimator will charge at peak outtput then, it can't at an idle.
96 Tracker
32 MTR's Warn 8000i
Offline Mike71
  • 1449
« Reply #46 on: October 24, 2004, 10:42:44 AM »
u can always run a batt isolator so that only ONE batt is used for the car..and the other for the goodies
that is how my car was going to be setup
623hp kb cobra sold! 100hp kick new DD :P
