2002 chevy Tracker purchase
  • 9 Replies
  • 5017 Views
Offline bmccoy
« on: January 20, 2019, 08:32:43 AM »
Am dealing on a 2002 Chevy Tracker, 2.0L 4, completely stock, 250,000km on odo. looks very clean, no rust, everything working.
Owner states it use's about a litre between changes and it has a torn lower boot on front CV shaft.
Are there any known issues with this model and yr. I should be looking out for??
thanks in advance for any tips!
Offline OldBlue
  • 48
Re: 2002 chevy Tracker purchase
« Reply #1 on: January 20, 2019, 09:12:58 AM »
I bought a 2002 4dr yesterday! 160K miles which may be close to your km reading. Both sound normal for a high mileage vehicle.
You can expect, as I can expect, some maintenance to be needed. Everything works on mine too but it needs shocks & struts.
I hope to do a small lift & slightly oversized tires.
Good luck should you buy the one you are looking at.
'02 Chevy Tracker 2.0 4wd 4dr
« Reply #2 on: January 20, 2019, 09:37:08 AM »
Try to hear it start up "from cold" - listen for timing chain rattle (any rattle from the front of the engine) - a second or two is acceptable, any longer than that is an indication of poor maintenance, and potential problems down the road.  Check the front suspension cross member for corrosion - some vehicles did not have enough protection and the cross member rotted from the inside out.
Offline bmccoy
« Reply #3 on: January 20, 2019, 01:04:03 PM »
Thanks,
The using oil concerns me.  Is this a norm in this engine at this mileage?
« Reply #4 on: January 20, 2019, 01:24:14 PM »
A liter between changes doesn't mean much to me - what's the oil change interval?   5000 kms?  I'd say that's not excessive for an engine with 250,000 kms on it.
Offline JollyZuk
  • 284
« Reply #5 on: January 24, 2019, 04:46:15 AM »
I don’t think a liter between changes would even be enough to get a warranty repair on a new car.  Once you get into it, you might find a couple of small oil weeps and seeps that could be responsible for most of that useage.
1995 Sidekick JLX
OEM ROOF RACK!!!
Offline bmccoy
« Reply #6 on: February 02, 2019, 04:08:25 PM »
Made the Decision! Am now the proud owner of a 2002 tracker.
Offline JollyZuk
  • 284
« Reply #7 on: February 08, 2019, 08:00:51 PM »
That is a sharp looking rig!  Congrats!
1995 Sidekick JLX
OEM ROOF RACK!!!
Offline Phase change
  • 199
« Reply #8 on: February 20, 2019, 08:24:09 AM »
I predict this will be your favorite car to date.  I love mine, they just work and they get it done with minimal breakage and maximum comfort for the cost.
Offline OldBlue
  • 48
« Reply #9 on: March 05, 2019, 10:27:00 AM »
Nice BMCCOY. Looks like a deluxe version compared to my base model!
