2002 chevy Tracker purchase
  • 9 Replies
  • 5639 Views
Offline bmccoy
  • ZUKIWORLD Online!
« on: January 20, 2019, 08:32:43 AM »
Am dealing on a 2002 Chevy Tracker, 2.0L 4, completely stock, 250,000km on odo. looks very clean, no rust, everything working.
Owner states it use's about a litre between changes and it has a torn lower boot on front CV shaft.
Are there any known issues with this model and yr. I should be looking out for??
thanks in advance for any tips!
Offline OldBlue
  • 48
  • ZUKIWORLD Online!
Re: 2002 chevy Tracker purchase
« Reply #1 on: January 20, 2019, 09:12:58 AM »
I bought a 2002 4dr yesterday! 160K miles which may be close to your km reading. Both sound normal for a high mileage vehicle.
You can expect, as I can expect, some maintenance to be needed. Everything works on mine too but it needs shocks & struts.
I hope to do a small lift & slightly oversized tires.
Good luck should you buy the one you are looking at.
'02 Chevy Tracker 2.0 4wd 4dr
Offline fordem
« Reply #2 on: January 20, 2019, 09:37:08 AM »
Try to hear it start up "from cold" - listen for timing chain rattle (any rattle from the front of the engine) - a second or two is acceptable, any longer than that is an indication of poor maintenance, and potential problems down the road.  Check the front suspension cross member for corrosion - some vehicles did not have enough protection and the cross member rotted from the inside out.
Offline bmccoy
  • ZUKIWORLD Online!
« Reply #3 on: January 20, 2019, 01:04:03 PM »
Thanks,
The using oil concerns me.  Is this a norm in this engine at this mileage?
Offline fordem
« Reply #4 on: January 20, 2019, 01:24:14 PM »
A liter between changes doesn't mean much to me - what's the oil change interval?   5000 kms?  I'd say that's not excessive for an engine with 250,000 kms on it.
Offline JollyZuk
  • 284
  • ZUKIWORLD Online!
« Reply #5 on: January 24, 2019, 04:46:15 AM »
I don’t think a liter between changes would even be enough to get a warranty repair on a new car.  Once you get into it, you might find a couple of small oil weeps and seeps that could be responsible for most of that useage.
1995 Sidekick JLX
OEM ROOF RACK!!!
Offline bmccoy
  • ZUKIWORLD Online!
« Reply #6 on: February 02, 2019, 04:08:25 PM »
Made the Decision! Am now the proud owner of a 2002 tracker.
Offline JollyZuk
  • 284
  • ZUKIWORLD Online!
« Reply #7 on: February 08, 2019, 08:00:51 PM »
That is a sharp looking rig!  Congrats!
1995 Sidekick JLX
OEM ROOF RACK!!!
Offline Phase change
  • 199
  • ZUKIWORLD Online!
« Reply #8 on: February 20, 2019, 08:24:09 AM »
I predict this will be your favorite car to date.  I love mine, they just work and they get it done with minimal breakage and maximum comfort for the cost.
2003 Suzuki tracker 4d 5sp 2.0 “piglet”
Deleted air 4wd system, Manual hubs, 2” lift, 235/75,
Old ride: 1997 X90 “jellybean” best lil car I’ve ever had
Offline OldBlue
  • 48
  • ZUKIWORLD Online!
« Reply #9 on: March 05, 2019, 10:27:00 AM »
Nice BMCCOY. Looks like a deluxe version compared to my base model!
