annoying death beep
  • 24 Replies
  • 12344 Views
Offline rkteckt
  • 214
  • I love YaBB 1G - SP1!
Re: annoying death beep
« Reply #15 on: December 20, 2005, 08:48:04 AM »
Well after researching a bit it souds like the door switch is 'grounded out'   but cutting it off doesnt help....i know this cause i got frustrated and cut it off......  ;D  so is there a way to just disconnect that circuit?  it looks like the only things on it are hte door switch and interior light.  Is there  a way to disconnect it at the interior light?
« Last Edit: December 20, 2005, 09:09:49 AM by rkteckt »
1991 samurai , Mall Crawler, neon green, YJ lift, Wifes vanity plates.
1988.5 tintop too many mods to list. The work samurai.
2005 Avalanche Z71
2003 Matrix XRS
1993 sidekick 4dr 2wd donor thats too nice to destroy yet. 1992 Toyo Pup POS
« Reply #16 on: December 20, 2005, 09:41:18 AM »
Just search for the beeper noise maker,
and remove it, or you could take it apart
and cut the wire to the beeper thing then
plug it back in if things stop working right.
Offline rkteckt
  • 214
« Reply #17 on: December 20, 2005, 07:53:10 PM »
Believe me if i knew where it was i would go after it with a hedge trimmer at this point.  It doesnt show up on the wiring diagram, and it kind of sounds like it is coming out of the ECU.....which would suck.
2005 Avalanche Z71
2003 Matrix XRS
Offline ROSS
  • 1412
« Reply #18 on: December 20, 2005, 07:59:33 PM »
is that the black one about one inch square mounted on the back of the instrument cluster
                                                               Ross
Offline 89kick
  • 27
  • I LOVE MY LIL ZUK
« Reply #19 on: December 21, 2005, 09:47:09 PM »
hmm interesting oh btw the ding ding for the keys being in there for those of use without soft tops.... if we lock our keys in were screwed, nothing but glass and sheet metal to work around to get into it.  trust me it sucks when your stranded out somewhere without a coat hanger and have to run to a phone to call a cop to unlock your doors.
*89 kick, witha  6" calmini super articualtion combo lift.  New interior 100% 1/8inch neoprene seats that 100% waterproof.  33x12.50 Wild Country EXTs on 15x10 slotted mag alumminum wheels.  Comp level Stereo system. and the Stock 1.6-8valve for now.
Offline prairie_dog
  • 234
  • 85/413 tin top
« Reply #20 on: December 21, 2005, 11:19:46 PM »
 The beeper in mine was a little black box ( 1" by 2") screwed to the back of the insterment panel, phillips screw driver and 2 wires (red & black) and the noise is gone.
 Funny how little things can be so frusterating, think I smashed mine with a BFH but I felt better after ;)
 Steve :)
When this thing hits 88 MPH your gonna see some serious sh!t (hahaha)
Offline keith
  • 1176
« Reply #21 on: December 22, 2005, 12:20:53 PM »
That's why they all should be softtops! :)
Offline 89kick
  • 27
  • I LOVE MY LIL ZUK
« Reply #22 on: December 24, 2005, 12:38:10 AM »
yeah but those of us with hardtops can keep our girls nice and toasty in -30 degree weather too :)
Offline Yoak
  • 577
« Reply #23 on: December 26, 2005, 11:37:19 PM »
The beeping wire(for a lack of better words) (on my 93 kick)
is connected only to the driver side pin switch, I belive it is black with a brown stripe....if you cut it or eliminate a negative connection no more beeping...I acually made a switch so i can turn it on and off as needed...
If you still need overhead light you splice into the other door jam switch wire
Offline rkteckt
  • 214
« Reply #24 on: December 27, 2005, 05:26:10 PM »
Ok,
I had to go to my local mechanic, took him about 4 seconds to find it.....
Its a wire connection on the far right side of the dash under the glove box, kind of up high right near the front plastic of the dash, he pulled the plug and the dinger stopped.......
You know the metal tube that the glove box kind of sits on?  i think it is between that tube and the front of the dash......
Have fun with it.
2005 Avalanche Z71
2003 Matrix XRS
