5.83 gears from calmini?
zukzilla1662
90
I Love ZUKIWORLD!
September 20, 2006, 05:06:43 PM »
what could i run for tires on my samurai with these gears right now im running 32's with stock gearing and motor? i want to go bigger tire size so would 5.83's be good?
chet
556
Zuki time!
Re: 5.83 gears from calmini?
September 21, 2006, 08:16:54 AM »
I would suggest going with 5.13 track kick gears and doing tcase reduction to get the rest of the reduction. You will get low range reduction that way as well. A friend has 4.62's with 4:1 tcase gears and turns 32's like stock.
Drone637
8121
116
Evil Cow
September 21, 2006, 01:53:00 PM »
There is a couple arguments on this, you can search the board for a couple arguments on T-Case VS Diff gears. A set of 6:1 or higher transfer case gears should bring you into stock for high range, and give you the low range boost.
toomeymd
296
I Love ZUKTAH!
Reply #3 on:
September 21, 2006, 04:22:50 PM »
5.38's are WAY low for street, I just blew my head gasket, rpm's were too high. My buddy runs 4.62's from a tracker with 33's, he loves it.
Suzuki Rocker
