5.83 gears from calmini?
  • 2144 Views
Offline zukzilla1662
  • 90
« on: September 20, 2006, 05:06:43 PM »
what could i run for tires on my samurai with these gears right now im running 32's with stock gearing and motor? i want to go bigger tire size so would 5.83's be good?
Offline chet
  • 556
  • Zuki time!
Re: 5.83 gears from calmini?
« Reply #1 on: September 21, 2006, 08:16:54 AM »
I would suggest going with 5.13 track kick gears and doing tcase reduction to get the rest of the reduction. You will get low range reduction that way as well. A friend has 4.62's with 4:1 tcase gears and turns 32's like stock.
« Reply #2 on: September 21, 2006, 01:53:00 PM »
There is a couple arguments on this, you can search the board for a couple arguments on T-Case VS Diff gears.  A set of 6:1 or higher transfer case gears should bring you into stock for high range, and give you the low range boost.  :)
Offline toomeymd
  • 296
  • I Love ZUKTAH!
« Reply #3 on: September 21, 2006, 04:22:50 PM »
5.38's are WAY low for street, I just blew my head gasket, rpm's were too high. My buddy runs 4.62's from a tracker with 33's, he loves it.
Suzuki Rocker
