95 kick blows fuses
  • 1394 Views
phloop
95 kick blows fuses
« on: November 09, 2007, 09:44:51 PM »
Any one have an idea why a '95 Sidekick will blow the Ign. fuse when you try to start it? Looking at one as a DD that has this problem and may get a decent deal if it is a simple fix.
TIA
Offline sidekicksrock
  • 416
  • Lil Suzys Dad
Re: 95 kick blows fuses
« Reply #1 on: November 09, 2007, 10:28:11 PM »
That would be a dead short in the ignition system. It probably is an easy fix but you will need to trace the wiring. Does it blow the fuse when the ignition is turned to on or only when the ignition is turned to start?
Student of Now Master of Then
Offline Mikerpm4x4
  • 2875
  • 12
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #2 on: November 09, 2007, 11:04:30 PM »
unplug the o2 sensor and see if it still does it. The preheater may have a short.
Mike
Offline brentd27
  • 101
« Reply #3 on: November 10, 2007, 04:05:15 PM »
If it does it just when it's turned to start, it's probably a short either in the solenoid, or possibly the activator wire had come off the terminal and is touching ground.
