Check Engine Light
Check Engine Light
SFZUKI
10
GIT-R-DONE!
Check Engine Light
March 25, 2006, 07:00:01 PM »
on a 86 zuki
Does anybody know how to reset the check engine light
Is there a place on the net that I can look up the codes
kymike
87
I Love ZUKIWORLD!
Re: Check Engine Light
March 25, 2006, 07:05:39 PM »
is it solid or flashing
SFZUKI
10
GIT-R-DONE!
March 25, 2006, 07:06:29 PM »
it's flashing
kymike
87
I Love ZUKIWORLD!
Reply #3 on:
March 25, 2006, 07:16:29 PM »
if you look back a week or two i posted the same question and there is some info i have had 3 samis and i have never had any luck finding codes there is a 4 prond connector that is suppose to be behind the battery or under the dash and you jump 2 of the pins and you schould get your code good luck finding it i even took one to suzuki dealer and they couldnt find test point
urbanwheeler
696
I Love ZUKIWORLD!
Reply #4 on:
March 25, 2006, 07:18:03 PM »
There is a switch under the dash near the steering column, and that is what resets the check engine light.
SFZUKI
10
GIT-R-DONE!
Reply #5 on:
March 25, 2006, 07:21:55 PM »
kymike, I can check back in a few weeks, I don't have to smog it to May. I have plenty of time.
Thanks urbanwheeler for the location of the switch
ROSS
1412
WHY TAKE A PICTURE WHEN YOU CAN DRIVE OVER IT
Reply #6 on:
March 25, 2006, 07:28:06 PM »
try
www.troublecodes.net/suzuki/index.shtml
87 SAMI 1600 FUEL INJ. , TORQUER CAM, 6.5 TO 1T-CASE, 5"SPRINGS SHACKLE REVERSE ,2 BODY LIFT, LOCK-RITES FRONT W/ HEAVY-DUTY AXLES & ARB'S REAR BFG 31 X10.50 X 16", EXO SKELLETON,
kymike
87
I Love ZUKIWORLD!
Reply #7 on:
March 25, 2006, 07:50:30 PM »
the switch under the dash only reset when it is solid it comes on at 60000 and 100000 i think
Jookycola
372
1995 Tracker LSi 4x4 16v 2-door
Reply #8 on:
March 25, 2006, 11:28:43 PM »
yep 60,000 and 100,000. my problem is i just went over 100,000 and i'll be damned if i can remember where that little switch is located on my 1995 Trackick. anybody know where i can find it?
[/url]
derekj
784
i'm the canadian guy eh?
Reply #9 on:
March 26, 2006, 02:01:22 PM »
obd1 vehicles - disconnect the battery for 1 minute and codes are cleared.
derek
91 Sidekick jx
2" BDS supension lift
2" BDS body lift
1" Coil spacers
32" TSL's and some other stuff I did And now with a Lockrite!
www.cardomain.com/memberpage/783382
SFZUKI
10
GIT-R-DONE!
Reply #10 on:
March 26, 2006, 09:05:46 PM »
Thanks found the switch by the steering column, all better.
