Check Engine Light
  • 10 Replies
  • 2482 Views
Offline SFZUKI
  • 10
  • GIT-R-DONE!
Check Engine Light
« on: March 25, 2006, 07:00:01 PM »
on a 86 zuki  :)
Does anybody know how to reset the check engine light ???
Is there a place on the net that I can look up the codes ???
Offline kymike
  • 87
Re: Check Engine Light
« Reply #1 on: March 25, 2006, 07:05:39 PM »
is it solid or flashing
Offline SFZUKI
  • 10
  • GIT-R-DONE!
« Reply #2 on: March 25, 2006, 07:06:29 PM »
it's flashing
Offline kymike
  • 87
« Reply #3 on: March 25, 2006, 07:16:29 PM »
if you look back a week or two i posted the same question and there is some info i have had 3 samis and i have never had any luck finding codes there is a 4 prond connector that is suppose to be behind the battery or under the dash and you jump 2 of the pins and you schould get your code good luck finding it i even took one to suzuki dealer and they couldnt find test point
Offline urbanwheeler
  • 696
« Reply #4 on: March 25, 2006, 07:18:03 PM »
There is a switch under the dash near the steering column, and that is what resets the check engine light.
Offline SFZUKI
  • 10
  • GIT-R-DONE!
« Reply #5 on: March 25, 2006, 07:21:55 PM »
kymike,  I can check back in a few weeks, I don't have to smog it to May. I have plenty of time.
Thanks urbanwheeler for the location of the switch
Offline ROSS
  • 1412
« Reply #6 on: March 25, 2006, 07:28:06 PM »
Offline kymike
  • 87
« Reply #7 on: March 25, 2006, 07:50:30 PM »
the switch under the dash only reset when it is solid it comes on at 60000 and 100000 i think
Offline Jookycola
  • 372
« Reply #8 on: March 25, 2006, 11:28:43 PM »
yep 60,000 and 100,000.  my problem is i just went over 100,000 and i'll be damned if i can remember where that little switch is located on my 1995 Trackick.  anybody know where i can find it?
  [/url]
Offline derekj
  • 784
  • i'm the canadian guy eh?
« Reply #9 on: March 26, 2006, 02:01:22 PM »
obd1 vehicles - disconnect the battery for 1 minute and codes are cleared.
derek
91 Sidekick jx
2" BDS supension lift
2" BDS body lift
1" Coil spacers
Offline SFZUKI
  • 10
  • GIT-R-DONE!
« Reply #10 on: March 26, 2006, 09:05:46 PM »
 :D Thanks found the switch by the steering column, all better.
