any way to reset check engine light on 97 sidekick
pbgbottle
76
October 10, 2005, 05:49:39 PM »
i searched . and came up the info about the switch behind the speaker .but i don't think this apply's to the newer sidekicks . anyway to reset the computer .on a 1997 sidekick 4dr. hit the 130000 km mark . any info would be great  thanks Jake
1997 suzuki sidekick
4dr. auto
Calmini 6 inch
31x10.5 yokohamas on american racing 15x7
see the machine at
http://www.cardomain.com/id/pbgbottle
TN_Tracker
1113
Re: any way to reset check engine light on 97 sidekick
October 10, 2005, 07:38:59 PM »
There ain't no switch on a '97, you need a code scanner to see why you have a CEL. In the states Autozone will tell you for free.
rottyfan
15
I love YaBB 1G - SP1!
October 11, 2005, 03:53:12 PM »
Have you tried disconnecting the battery for about ten minutes? That should clear your computer. If it comes back on, then you have to hook up a code scanner to find out what is causing the light to come on. Good luck
Annoy a Liberal:
Work, Succeed, Be Happy
pbgbottle
76
Reply #3 on:
October 17, 2005, 06:50:59 PM »
thanks for the info guys i got a code scanner off of ebay .
error code 135
O2 sensor heater circuit malfunction (cylinder bank no. 1, sensor no.1 )ÂÂ
does this pretty much mean i need a new o2 sensor???
4dr. auto
Calmini 6 inch
see the machine at
