any way to reset check engine light on 97 sidekick
  • 3266 Views
Offline pbgbottle
  • 76
« on: October 10, 2005, 05:49:39 PM »
i searched . and came up the info about the switch behind the speaker .but i don't think this apply's to the newer sidekicks . anyway  to reset the computer .on a 1997 sidekick 4dr.  hit the 130000 km mark .  any info would be great    thanks Jake
1997 suzuki sidekick
4dr. auto
Calmini 6 inch
31x10.5 yokohamas on american racing 15x7
see the machine at http://www.cardomain.com/id/pbgbottle
Offline TN_Tracker
  • 1113
    • TN Tracker's Suzuki Space
Re: any way to reset check engine light on 97 sidekick
« Reply #1 on: October 10, 2005, 07:38:59 PM »
There ain't no switch on a '97, you need a code scanner to see why you have a CEL. In the states Autozone will tell you for free.
Offline rottyfan
  • 15
« Reply #2 on: October 11, 2005, 03:53:12 PM »
Have you tried disconnecting the battery for about ten minutes?  That should clear your computer.  If it comes back on, then you have to hook up a code scanner to find out what is causing the light to come on.  Good luck
Annoy a Liberal:
Work, Succeed, Be Happy
Offline pbgbottle
  • 76
« Reply #3 on: October 17, 2005, 06:50:59 PM »
 thanks for the info guys i got a code scanner off of ebay .
 error code 135
O2 sensor heater circuit malfunction (cylinder bank no. 1, sensor no.1 )
does this pretty much mean i need a new o2 sensor???
4dr. auto
Calmini 6 inch
