transfer case shimmy?
  • 21 Replies
  • 6191 Views
Offline zookiemike
  • 474
  • $,reppin Michigan,$
Re: transfer case shimmy?
« Reply #15 on: March 30, 2005, 07:46:40 PM »
Bent tcase arm. The long one. Just went thru this on mine last week.
As we moving with the speed of the robot sonic exhaust
Chronic fumes, fuel, gin, and tonic
Half of the world is corrupt and alive
The other half is depressed and they want to die
Offline lazarus
  • 32
  • I love YaBB 1G - SP1!
« Reply #16 on: March 31, 2005, 12:33:37 AM »
I doubled up the main springs on the rear of mine and nither one of mine have that prob. I have pulled a thousand pound trailer up to eight five mph even and up a hill no less and never noticed anything.
I buy the double main spring statement, BUT
a samurai going uphill at 85 mile an hour towing a 1000 lb. trailer!
It was on the trailer, correct?
no good deed goes unpunished
Offline takai
  • 907
« Reply #17 on: March 31, 2005, 07:54:47 AM »
Have to ask that one myself? I am planning on an engine swap in a bit. I want what you got under the hood. Just for the expression on peoples faces, if for no other reason.   ;D
'Cause, I am to misbehave.
Offline mrfuelish
  • 2862
« Reply #18 on: March 31, 2005, 08:06:18 AM »
Ya I was running a 16 valve with a four to one x-fer case with 30x9.5 tires, pulled in the scales just starting off on the nine day camping trip the rig and the trailer weighed in at 4000 lbs  the trailer by its self weighed 950 with about 50 lb tounge weight, it still had plenty of more power to go faster but why push it ? that was with an inch and seven eights exhaust pipe, I got home and put a two inch pipe on it now it has ever more power.It did real well on gas mileage also I went from klamath falls oregon to lake view over the mountains and it took 3.8 gal of gas. just did the math 28.4 mpg. p.s. the trailer I was pulling is a 1951 m100 that goes with my m38a1 (looks like a cj-5)about 500 lbs empty.
« Last Edit: March 31, 2005, 08:13:44 AM by mrfuelish »
Offline takai
  • 907
« Reply #19 on: April 01, 2005, 11:12:38 AM »
I know those roads! I live in GP. I am impressed.  :o
Offline LawDog
  • 531
  • Lakeview Motor Sports' Makin it Hert! Tell u whut!
    • Emerling Chevrolet
« Reply #20 on: April 02, 2005, 02:12:23 AM »
driveline vs. pinion angle
I would agree, but with no mods, what would be causing it?
"I'm the Law 'round here" said the Duckshirt.
Get a Zuk, Get it dirty, Git-R-Done!!
At Lakeview Motor Sports we specialize in rediculousness, hackdome, and wasting your time.
Offline budzooka
  • 53
« Reply #21 on: April 02, 2005, 02:32:19 PM »
turns out it was the rear ujoint on the small shaft going from tranny to trans case. all better now :)
Please post back on here when you find out what it is! :) Mine is doing the same thing,  (albeit I have two transfer cases)... but I was thinking that it might be the output shaft bearing on the Samurai transfer case. It makes noise in 5th gear when you let it off too.
If that is what you find out, then it just reaffirms my suspicion. Thanks!
PS. I plan to take mine apart in the next couple of weeks to see for sure what is causing mine too..
Heather
« Last Edit: April 02, 2005, 02:33:30 PM by newzuki »
