New headlights not working
  • 1480 Views
Offline treydare
« on: January 10, 2020, 07:27:15 AM »
Hey guys, I got some new led headlights for my 88 sami that were said to be plug and play but once i got them plugged in they would not work. I've seen other sami's with the same headlights and was wondering if there is a pigtail needed to get them to work?
Re: New headlights not working
« Reply #1 on: January 10, 2020, 08:58:04 AM »
Remember we have to work with what you tell us - judging from the picture, what you have is not just new headlights, but LED headlights and that is where your problem lies - LED headlights are "polarity sensitive" - you need either lights designed to work with a negative switched wiring system - now go back to your supplier and ask them if they do a harness for the lights you bought to work with a negative switched system.
Offline RJkick
  • 634
« Reply #2 on: January 10, 2020, 10:43:31 AM »
I just replaced a 2004 Ford Econoline Van and found M4Products to be very helpful.  I don't know if they would have anything you need but they are very knowledgeable on LED's period and are happy to talk to everyone
Offline treydare
« Reply #3 on: January 10, 2020, 12:33:11 PM »
Thank you, i did some research on them and turns out the headlights were falsely advertised. I found a conversion harness on low range offroad that looks as though it will fix the problem.
