C-Clips in the hub (lockout): POLL!
  • 10 Replies
  • 2838 Views
  • 6589
« on: September 12, 2005, 07:03:28 AM »
The question has come up a couple of times in different discussions about using the c-clip in the hub (lockout). Some do and some don't.. So, this looks like a good time to post a poll and tally up the vote!
Thanks, Eric
« Last Edit: September 12, 2005, 09:49:31 AM by ebewley »
Offline ed oorklep
  • 637
  • 1992 Suzuki Vitara
    • Suzuki Vitara 4x4
Re: C-Clips in the hub (lockout)
« Reply #1 on: September 12, 2005, 07:31:39 AM »
I think it's there for a reason, but my new stronger CV's are on there way so I guess I'll see if it is needed  ;) I've got one not on now I believe (haven't looked yet) but that makes some noise, so it might be not the best to have 'm out...... :-\
http://www.suzukivitara4x4.nl
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #2 on: September 12, 2005, 07:35:48 AM »
My Toyota CV axles have a C-Clip - but it seems to be there to hold it OUT, rather than IN, so I don't think it matters.  Also, I've got a big flat-washer and bolt on the end of the axles - I do have THAT installed.
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Re: C-Clips in the hub (lockout): POLL!
« Reply #3 on: September 12, 2005, 10:14:35 AM »
The one under the hub? Its there to stop the shaft pulling out of the hub at full droop. If the shaft pulls back then the wheel bearings are exposed and can get full of crud. Of course if you're CVs are on the limit and you only drive in rocks then leaving it off might save you a breakage.
Offline blacknight
  • 987
    • Gonzookin
« Reply #4 on: September 12, 2005, 11:31:34 AM »
I've had my pull out with c-clip in  :-[
George
Offline SnoFalls
  • 1358
« Reply #5 on: September 12, 2005, 12:52:26 PM »
I'm running my trac/kicks with 'em, just cause I've had no reason to not ...
If I was breakin CV's, I'd probably do the mod to have the pass side like the drivers, and then without a the clip could change either CV in about 5 minutes :)
« Reply #6 on: September 12, 2005, 02:31:19 PM »
George
Time to check how much CV travel you have left at full droop.
Offline mesjr2004
  • 422
« Reply #7 on: September 12, 2005, 03:37:51 PM »
never put them back in my sammy or anything else . i was breaking a birfield or 2 every time i went wheeling , so if it didnt keep it from working properly it didnt go back in . especally that clip on the axel that holds the birfield in . wow some of thoes are a bitch to get apart.
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
« Reply #8 on: September 13, 2005, 07:47:38 AM »
This needs to be more specific. Sammys use a c-clip that holds the lock-in/lock-out hub onto the end of the axle splines and Trackers use a c-clip under the lock-in/lock-out hub to hold the cv splines into the spindle/wheel bearing...
Offline ed oorklep
  • 637
    • Suzuki Vitara 4x4
« Reply #9 on: September 13, 2005, 09:15:28 AM »
If you have a lifted one (trackkickvit) you should leave them in , I have one out (left side) and only have RWD it'll be fixed quickly enough but it's anoyying when you want to make some poser shots  ;D
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #10 on: September 13, 2005, 03:51:18 PM »
I left them out and used a bolt and washer (the end the the shaft is threaded) to hold the axil in.  Never had a problem with them falling out.  Braking, yes, falling out no.
96 Tracker
32 MTR's Warn 8000i
